So besides hunting down this information from one source at a time, and wasting hundreds of hours understanding technical specifications (which not everyone can understand)...how would the user know which of these to buy?
We have buying guides for speakers, subs, and room correction....but nothing for amplifiers?
How did this happen? This is a major fail, IMO.
Since we are talking about opinions, mine is that buyers should not worry about what module is used but the overall performance.
I like taking the DAC chips as an equivalence. Some have everything embedded and the resulting performance is basically given by the datasheet, others need proper clocking, a nice I/V, filtering, ... And ASR users know very well that the chip doesn't do the performance.
If you take a NC252MP, it is almost plug and play, butchering it's implementation seems tricky and they basically all measure the same. Like an ES9080 chip. Now, on the other side of the spectrum you have the 1ET9040BA. Stellar performance, no integrated buffer or power supply and low input impedance. There is no way to have an amplifier at the level of the announced performance without a bit of work. Think composite opamp as a minimum. Equivalent would be the ES9039PRO.
Buying guides for DACs are based on the final product performance, it should be the same for amps.
IMHO.
