Yes of course the 1200 if I recollect initially they would only sell them to manufacturers whose finished amp product had a retail price over a certain amount .It was the NC1200. This one is the "upgrade". Not a fan of the form factor at a first glance.
If it helps this huge power makes more sense to huge speakers playing loud levels. More of a niche. The regular NCx500 with "only" 700W into 4 ohms is already plenty.repeat after me: I don't need a new amp. I don't need a new amp.
nice to have another option, and likely few golfing/football panthers looming, but my wallet is already light enough
no it was a joke. McIntosh has 1.2kW monoblocks so people will find uses for this. or so they think.If it helps this huge power makes more sense to huge speakers playing loud levels. More of a niche. The regular NCx500 with "only" 700W into 4 ohms is already plenty.
Yes and no. The 1ET90BA will cope better with low impedance speakers, the NCx1000 with high impedance ones. TBH, I am a bit disappointed to see that 4R power is higher than 2R power.A bridged NCx500 with 1400W into 4 ohms at 7 uV output noise, wow. This thing is a competidor to the announced Purifi 1ET9040BA it seems.
People will just need to understand that the amplifier input stage now makes a significant difference on measurements with such high performance modules.It has less output noise than Purifi 1ET400A (~11.5 uV) for reference. And since the typical SINAD at 5W is mainly defined by noise (distortion comes only with higher power), the NCx1000 should have a very high SINAD. Smarter folks than me can do the math and already predict.
Edit: the 1ET9040BA has 8 uV and SINAD 117 so the NCx1000 with 7 uV should be around there too.
Why is that?If it helps this huge power makes more sense to huge speakers playing loud levels. More of a niche. The regular NCx500 with "only" 700W into 4 ohms is already plenty.
Which ones? AFAIK it does not even come close to that.Why is that?
If we take mid-size actives as a reference 1kW for lows only is usually the norm.
Mains monitors much-much higher than that.
Not so far if we take into account the losses of the passive x-over,needed EQ,etc.Which ones? AFAIK it does not even come close to that.
Examples:
Genelec 8361 - 700+150+150=1kW total
Neumann KH 420 - 295+130W=425W total
Focal Trio11 Be - 300+150+100W=550W total.
I noticed the description below on the brochure:TBH, I am a bit disappointed to see that 4R power is higher than 2R power.
1ET9040BA has 4.5uV. (First time I saw the module the prototype had 8uV, but they have improved it in the meantime.)
The bridged NCx500 will probably not service 2 ohm loads- same with the Purifi or is it bridged as well?
