wacomme
- Joined
- May 11, 2022
- Messages
- 428
- Likes
- 110
I'm trying to add a pair of powered stereo speakers to a TV so that can bypass the small and poor sounding TV speakers. I'm not looking for anything fancy - I'll be using some old AudioEngine A2 speakers with RCA and 3.5mm inputs. I can do this with optical out and a simple dac. However, I cannot control the TV volume with the TV or Xfinity remote. Is there an inexpensive way to connect the A2 speakers to my TV and have the volume controlled by the Xfinity remote?
I've read about HDMI ARC and how that connect allows for TV remote volume control. However the only HDMI ARC connection on the TV is hooked to the Xfinity cable box - and apparently the cable box requires a HDMI ARC connection. There's another HDMI connection on the cable box (as well as the TV), but they are not ARC connections. I've also explored HDMI audio extractors, but I don't think these devices allow for remote volume control either - lacking CEC? Do I need an AVR? I don't need anything fancy, just an improvement over the TV audio; the A2 speakers, themselves, are nothing fancy.
Anyway, is there a reasonably priced solution to my hookup problem?
