mhardy6647
- Joined
- Dec 12, 2019
- Messages
- 11,499
- Likes
- 25,031
I am not about to disagree with any of the above -- although when it comes to listening, I am a big fan of the (completely unaffordable, at my socioeconomic level) big ol' tar-filled multicell horns (e.g., 1505) coupled to a 288 family member.Actually the A7 / A7-500 measure just about as well as any modern speaker if executed well, for instance if active crossovers are used and some voicing is used especially on the HF driver.
As far as polar response, I think that is basically a useless specification unless there are going to be critical listeners well off-axis. As far as I'm concerned, the high directivity (and yes 'beaming') of these VOTT speakers is a virtue, not a liability. Good holographic imaging comes from the recording. Any sound coming from the walls of the room is distortion of the inherent spatial qualities of the recording. High directivity preserves as much of the recording's imaging qualities as possible.
Gary Kaufman's A5s -- augmented with a split 210 LF horn loaded with 515Bs acting as subwoofers.
As Rolls-Royce famously used to say of their engines' power specification:
"Adequate."
