Help! REW Problem with sweeps
Fernando
Spain, Europe.
Hello.
When I do a measure there is no problem, but when I do 2 or 4 sweeps some falls appear that I can't understand.
Why is it, I have something wrong configured?
Jdunk54nl
Arizona
How did you take all of this data? You need to be more specific. Did you move the mic between the sweeps when multiple? Was it always in the same spot? Same speaker? Etc.
Fernando
Fernando
Spain, Europe.
Sure! all in the same conditions of volume, position, etc ... only change of number of sweeps.
Jdunk54nl
Arizona
Are the sweeps averaged for that data? If so how did you average them?
Jdunk54nl
Arizona
What did you do to get the 2 sweeps and 4 sweeps as a single line? My gut reaction right now is comb filtering at the higher frequencies.
Fernando
Fernando
Spain, Europe.
REW sweeps and averages. Do you use REW?
I'll try the Sweep Delay, in case it's the cause, but I don't think so.
Jdunk54nl
Arizona
I've used REW quite a bit.
So is this what you did? (again these details on your exact stuff is important to help diagnose anything over the internet. Screenshots of settings really help)
Clicked on measure, set repetitions to 2 or 4 then measured?
daftcombo
In my opinion this is a REW bug.
I've had such weird behaviour and reported to John in the past.
daftcombo
Multiple sweeps are useless IME anyway.
Stick to single 256k.
