D
Deleted member 48726
Guest
That's a very polite way of telling people correcting FR is wrong because one man says so.To be frank, I think it's a business decision that firms like Mathaudio, Dirac, and Audyssey that do automatic room corrections need to sell you the idea that full corrections are in general a good thing to do. From their standpoint, the whole idea is that it's a fairly straightforward process, just put up the microphone at the main listening position and then the secondary ones, and the program will make corrections to the full frequency response and not just the bass region which could be seen as a lesser value considering it's such a small part of the full frequency range.
What they should do instead, which of course would destroy the straightforward process (the business strategy of an easy-to-use program), is they should give the users instructions on how to make gated measurements of their loudspeakers, which then the program should base the corrections for, from around 500Hz to 20kHz. The problem with such an approach is that it would make the whole process way more complicated (and would therefore likely be seen as too high of a step for the average consumer), as the users must be able to put both their speaker and the microphone as far from the room boundaries to get a large reflection-free measuring window as possible, which in turn would open up for many potential user errors.
As was mentioned by @dominikz, your situation seems to be an extreme case so the overall improvements of the corrections of the full frequency response are likely way better than no corrections at all. But it's still likely that corrections based on gated measurements above 500Hz, and room-based corrections under 500Hz would give you an even better result.
And even in less extreme situations than yours, I think people who like the sound of full corrections (based completely on none-gated measurements), mostly hear the improvements done to the bass region (which in most cases will give the largest improvement) and based on that overall impressions take it as granted that the full correction was the right thing to do, even if it's possible that some degrading may have come "with the package" of full corrections based on none-gated measurements.
My suggestion is that you figure out how you do gated measurements, make the corrections above 500Hz based on that, and leave the corrections under 500Hz to Mathaudio. I think that will improve your sound even further.
That is of course still "full range corrections", just that the corrections are based on the room response under 500Hz, and the rest are based on the direct response of your loudspeakers.
P.S. This post is not meant to upset anyone who has full belief in the firms that make automatic full-range correction programs, it's just that people like Toole who have done deep research in the field, have concluded that what the human sense of hearing "picks up" from the listening position is not the same as what a microphone picks up from the same spot, which is pretty clear if you just listen to the recorded signal and compare it to what you hear from the same spot.
Those people are not wrong, if they get better sound from FR correction.
I don't think it's fully understood what exactly Dirac Live does. So maybe don't make it a right or wrong situation. Even if you have done so with a lot of polite writing. But your P.S. at the bottom is just a "sorry but not sorry" for saying we are doing it wrong. And I don't think anyone has claimed that a microphone is the same as you ears. But on the other hand you can't just record from it and play it back to prove that point unless it's binaural recording.
I can not get a better sound (for me) than a FR house curve gives me in Dirac.
YMMV
"I place subs in corners and correct full range" Holdt
