artbur
I wanted to find out if I can hear a channel imbalance of 0.5 db and 0.25 db when listening with headphones. In order to simulate a channel imbalance I recorded some sounds with a mono microphone, duplicated the track in audacity and exported it with identical left and right channels, +0.25 db on the right channel and +0.5 db on the right channel. Then I used the ABX test in foobar.
What do you think? How much channel imbalance is acceptable? Do you correct an analog volume pot imbalance with DSP or how do you deal with it?
With my Topping L30 I found a volume pot position around 11:30h, where the imbalance is only 0.05 db, and for volume adjusting I use the digital monitoring volume control on the Motu M4.
Here are my audio test files: https://we.tl/t-KOENBrIRs5
Here are my listening test results:
foo_abx 2.0.6c report
foobar2000 v1.6.2
2021-01-01 21:15:22
File A: 0.0 db.flac
SHA1: 09ac649f010fd55c392e82d33d75168c98aaa673
File B: 0.5 db.flac
SHA1: b4b92931937298bd35881477d5a5f4a2a96b1c0c
Used DSPs:
Resampler (dBpoweramp/SSRC)
Output:
ASIO : MOTU M Series
Crossfading: NO
21:15:22 : Test started.
21:15:35 : 01/01
21:16:08 : 02/02
21:16:47 : 03/03
21:17:46 : 04/04
21:18:08 : 04/05
21:18:16 : 05/06
21:18:23 : 05/07
21:18:47 : 06/08
21:19:07 : 07/09
21:19:33 : 08/10
21:19:33 : Test finished.
Total: 8/10
p-value: 0.0547 (5.47%)
-- signature --
67aa97feb21c320f91d912259ee80221d13626e9
and
foobar2000 v1.6.2
2021-01-01 21:20:32
File A: 0.0 db.flac
File B: 0.25 db.flac
SHA1: 2baa949f2466a27fb86b3baaa47e9b6c7b0f6f4c
Used DSPs:
Output:
Crossfading: NO
21:20:32 : Test started.
21:20:57 : 00/01
21:21:49 : 01/02
21:22:15 : 02/03
21:22:41 : 03/04
21:23:05 : 04/05
21:23:44 : 04/06
21:24:32 : 05/07
21:25:15 : 05/08
21:25:25 : 06/09
21:25:48 : 06/10
21:25:48 : Test finished.
Total: 6/10
p-value: 0.377 (37.7%)
-- signature --
1db7013e4021d8cab8a0393a258c55e8d60b961a
foobar2000 v1.6.2
2021-01-01 21:15:22
File A: 0.0 db.flac
File B: 0.5 db.flac
Used DSPs:
Output:
Crossfading: NO
21:15:35 : 01/01
21:16:08 : 02/02
21:16:47 : 03/03
21:17:46 : 04/04
21:18:08 : 04/05
21:18:16 : 05/06
21:18:23 : 05/07
21:18:47 : 06/08
21:19:07 : 07/09
21:19:33 : 08/10
Total: 8/10
-- signature --
and
foobar2000 v1.6.2
2021-01-01 21:20:32
File A: 0.0 db.flac
Used DSPs:
Output:
Crossfading: NO
21:20:57 : 00/01
21:21:49 : 01/02
21:22:15 : 02/03
21:22:41 : 03/04
21:23:05 : 04/05
21:23:44 : 04/06
21:24:32 : 05/07
21:25:15 : 05/08
21:25:25 : 06/09
21:25:48 : 06/10
Total: 6/10
-- signature --
