GR Research LGK 2.0 Speaker Review (A Joke)
Rate this speaker:
    Votes: 364 87.5%
    Votes: 36 8.7%
  • 3. Fine (happy panther
    Votes: 7 1.7%
    Votes: 9 2.2%
voodooless
Netherlands
Harmonic distortion is anyway unfortunately not a great metric to correlate with audibility, would be more interesting to compare the intermodulation distortion of both where the 2-way KH80 would be also superior, see also
With these kind of distortion figures, IMD will be bad as well.
Then again, I would be a fan of having multitone measurements for speakers (and headphones). I think Amir tried that once and found too many issues with the comparably of the measurements. I’d say: give them anyway ;)
DanielT
Sweden - Слава Україні
Even for decent 3-way mid it's too small and heavy (= inefficient) at the same time.
I'd prefer something else. Even proper Seas Prestige will perform better.
Maybe not the most suitable either (midrange in three-way solution) but IF you had to do something with that driver? But as you say, there are others.:)
With that said, I'm not an experienced DIY but someone who SHOULD be is Danny! He is a professional.Professional, that he makes money on his speakers and the crossover upgrade he sells.
Also seen in the light of what Amir wrote:
"...fully finished pair ($ 1,038)"
It's a rip off!
thewas
Yes, although even worse compared to a multiway speaker where the other drivers are not affected by the modulation of the woofer.
Fully agree :)
MZKM
Land O’ Lakes, FL
Preference Rating
SCORE: 3.7
SCORE w/ sub: 6.5
Sensitivity: 80.7dB (300Hz-3kHz ; spec: 84dB)
Frequency response: +/- 4.1dB 80Hz-20kHz
thewas
It’s a 3-inch driver, the smallest that Amir has ever measured.
The Fostex he had tested though is also 3 inch, active and costs a fraction.
abdo123
Brussels, Belgium
The Fostex he had tested though is also 3 inch, active and costs a fracture.
What a cute little thing!
thewas
Really? What bones? :facepalm:;)
But distortion on these is also bad. Seems to be a lot less audible though.
Yes, probably less IMD. ;)
Fracture should be fraction of course, too few sleep last night. :facepalm:
There isn't a chance the 90db sweeps damaged the driver?
No. I run my distortion tests before the NFS scan. If the driver was damaged the spin would not look as good as it did.
JSmith
Algol Perseus
he and others think my reviews are a joke
Wow... what a complete asshat.
The only joke here is this kit speaker... is it a cruel joke on customers?
Not only do these drivers sound better than the previous generation but also even measure better.
Max peak power full range: 30 watts.
Max peak power with first two octaves removed: 60 watts.
JSmith
uwotm8
Well, this thing is actually a typical B-category DIY in a nutshell:facepalm:
I bet that a pair or 65mm Tectonic BMRs put in almost any junk box will sound overall better due to bass that part of it they can reproduce handling abilities
delta76
While this is a great review by Amir, and a great service to the society, I don't think anything will change sustainably, sadly. He will either ignore this, or dismiss the results as inaccurate/the methodologies are faulty/we can hear things that are not in measurements etc., and hist followers/believers will believe what he said.
Sometimes it's sad to be reminded about the world we live in, but well,
