And this one …
Here is another visualistion of the "speed" of "static" test signals compared with music:A 20kHz full scale sine is already more dynamic than all music: It goes from max positive to max negative and back again 20,000 times a second. Real music doesn't do this since the levels of high frequencies in music are much lower than a full scale test tone.
But on top of that - here is the time domain wave form of the multi-tone test signal. Also much more dynamic than real music due to the levels of high frequencies being the same as low frequencies. Yet the typical well performing DAC can reproduce it perfectly with inaudible levels of noise and distortion - as shown in the measured test result.
Electronic output stage measurements should not be confused with acoustic measurements of electrodynamic multi-way transducers incorporating complex crossovers.
Please see this post....
So after reading a few DAC reviews and watching a video about what all the measurements mean I was very surprised that all of them are static! Yet music is a rapidly changing phenomena. So I feel a very key important piece of the puzzle is missing in terms of understanding the performance of the measured devices.
Thanks for any input in advance.
Yes amplitude is only half the story, phase is the other half. You need both to get the impulse/step response.Don’t we need phase too? I ask because I think of step response and impulse response as that start and stop question and “pretty flat FR” speakers can look different.
There was a post here somewhere where someone (I know, not much help) posted in room mic recorded measurements of speaker impulses and compared them to the mathematical derivation from a freq. sweep he also mic recorded and they were almost identical.
Obviously this is centuries late in internet terms, but it would be really cool to see a comparison of the generated and recorded impulse using Deltawave. I have always wondered about this because the generated / calculated impulse will be missing any nonlinear effects like harmonic distortion, where the recorded one will show artifacts from them... I think.That was me.
I couldn't "believe" the calculations taken from a frequency sweep sine tone could recreate the "edges" of an impulse (single full scale sample) or step (in this case, a 10hz square wave).
So I sent these sounds through the speakers, and recorded them with Audacity, and compared them to the calculations taken from the REW swept sine test tone.
Impulse
Impulse Response
Presented for your amusement: Single Full Scale Bit sent through speakers, playback recorded in Audacity: Impulse response calculated from a ten second 10-24kHz sweep tone (three weeks ago) in REW: Well, I am amused.www.audiosciencereview.com
Step
Impulse Response
An audiophile chasing the sound of FM radio is a new one...Years ago, I stumbled upon an FM broadcast of musicians performing live in the studio. It sounded fantastic! I immediately started scratching my head trying to figure out why it sounded so much better than recorded music. I figured that the difference was timing. Since then, I've experienced nice improvements in vinyl playback by upgrading the power supply to the turntable motor. These upgrades resulted in more accurate and precise spinning of the disc.
I think you can export the generated IR from REW as a .WAV file, which could go into DW? Maybe I imagined that. You could use Voxengo Deconvolver to generate the IR if not.
DeltaWave can compute the impulse response from any music track, not just from a sweep. As long as you can compute the difference between the original source file and the output of a device, you can plot IR:
Let's take the multitone test as an example to illustrate what I mean. Given 2 devices that have the same exact multitone chart, isn't it possible for one of them to stabilize from silence to signal faster than the other? Couldn't one have cleaner transition from silence to signal than the other? Couldn't these things be audible and impact the listening experience? (be it in responsiveness or other ways)
What I would have liked to see is a test similar to the grey-to-grey test they do in monitors. That is I would like to see how fast the DAC stabilizes on that multitone signal from silence, and then how long does it take for it to stabilize back on silence once the signal is off. This would be sort of a equivalent to a black to white and then white to black test. Then another test could simulate transitioning between to different multitone configurations similar to a grey-to-grey test in monitors. That way we could have a measure for the response times of different devices. Other tests could test the cleanness of the transitions - did they overshoot? wiggle?
Well, again, this would tend to show up in the frequency / phase response charts...That’s an interesting idea indeed. It’s like the frequency response waterfall chart showing the nature of decay. Driven by a multi tone signal instead of a sweep signal.
I don’t think I have seen anything like this done before…
