salmo
- Joined
- Jan 4, 2024
- Messages
- 68
- Likes
- 83
The DA-400 is a DAC that was designed by Taga Harmony- European Polish-German cooperation and manufactured in China. From what I've learned, the company's origins date back to the 1990s, and the DA-400 premiered in 2023, based on the ES9038Q2M chip along with a 16-core XMOS. It can currently be purchased for about $180. As for the number of inputs and outputs, it's really rich! In addition, the small display - just right one and not too bright - displays the most important information. The case itself is compact and decently made, the connectors also look solid. I didn't expect much, but I thought that the implementation of the ES9038Q2M would be good enough to get SINAD of 100dB or 105dB, unfortunately.... I was wrong.
More about it here: https://www.tagaharmony.com/en/product/9107/da-400
Measurements taken using an E1DA Cosmos ADC with a JDS Labs Atom AMP 2 as a buffer. The software is Multitone Analyzer. I checked both left and right channels, but didn't observe significant differences between them.
I wasn't expecting much, but TD+N -80dB - I wasn't prepared for this. When I reduced the generator signal by about 2dB, the maximum I get was TD+N -81.5dB, so it's not much of an improvement:
I really started to suspect that maybe in this case it's some kind of driver or ASIO problem. I decided to disconnect the USB and feed an optical signal to the DAC, unfortunately the result was practically the same:
Maybe no serious measurements were taken during the design stage? Or maybe my copy is simply defective? Hard to tell. For comparison - this is how it looks like with the Micromega MyDAC, which is about 12 years old, It achieved juicy TD+N of -101dB with no problem:
I could end this whole thread there, but I feel obliged to post a little more information, so I'm throwing in a handful of basic measurements.
I feel disappointed, because I really visually and functionally liked this DAC. In addition - it was designed in the country where I live, but unfortunately - something did not go quite right. I didn't expect state of the art performance, but I thought that the implementation of ES9038Q2M would be at least decent. Measurements rather leave no illusions here. Probably when used as a simple DAC for a headphone amplifier and at normal listening levels it will not be audible, but already the cheapest dongles with CS43131 provide definitely better performance - the distaste after this test unfortunately remained:
