Full Range OR Coaxial?
nas
Lil' hijack of thread: what are the coax drivers available up to ~200EUR-USD/unit range?
I know Kartesian, Sica and Seas. Dayton and SB have too flawed units, Satori - in 300USD range. Others are in pro audio or car audio category. Did I miss some lesser known driver?
nisse.P
Or simply do a deep dive https://loudspeakerdatabase.com/search/type=Coaxial
My tiny coaxial is this one: https://www.thomann.de/se/the_box_pro_4_coax_speaker_mcx4.htm
Ardacer
You might find KEF's drivers on ebay or other sites too.
nas
Eighteen Sound is a leading designer and manufacturer of high quality professional audio loudspeakers
Beyma - also only pro audio
18 sound - also only pro pro audio
LaVoce - also only pro pro audio
Oberton - also...
Faital - also...
and others from the database are either pro, car or guitar
In my humble loudspeaker building experience, there are too many differences between pro audio and home/hi-fi speaker drivers. If some pro audio drivers sound ok-ish, ok or good - it is more of an exception or pure overengineering, as the main purpose of pro audio drivers is very different to home use hi-fi drivers. There are some situations where this is acceptable or the only reasonable/affordable option: like huge driver dimensions and huge SPL needed on a limited budget.
The assortment is very limited in hi-fi coax:
Dayton and SB - 2 drivers total in 30-60EUR range, both with flaws
SEAS, Kartesian and Sica - 5 drivers total, all in 100-220EUR range. There are more by SEAS, but they are very expensive
Satori - 1 driver ~300EUR
That is all. Maybe there are some cheaper Morel and some lesser known and tested TB and Peerless.
jaakkopetteri
Omnes CX3.1 / 3.3 should be decent if not great for the price
Reactions: nas
nas
Nice find!
Tweeter section geometry does not seem very hi-fi-ish, but still an option. It would be great to have someone to do cheap coax shootout: SB, Dayton and this one. Especially multitone distortion from 80-100Hz
jaakkopetteri
Nice find!
The tweeter has a surprisingly smooth response. Several retailers have measurements from a German magazine and there's also a "minigehäuse" project with measurements that you can find online.
I have a CX120 that I've been planning on tinkering with. Changing the surround to an inverted one should be interesting!
nisse.P
unfortunately behind a subscription, but it’s not that expensive and Google translate is quite good at the German to English translation.
For the money it seems to be an excellent mid high solution.
nas
It depends how we define "mid-high". There are many good well engineered and reasonably priced full-range 2.5-3.5 inch drivers which play with very very little distortion from 200-300Hz up to ~15k. TC9, PS95, B80 etc. Choose any. This is why small 3-3.5 inch coax drivers make very little sense.
EDIT: make very little sense if used from those 200-300Hz.
jaakkopetteri
While I think small full-ranges and WAW builds in general are very underappreciated, those will still beam significantly compared to a small coax. Apart from the questionable "phase coherence", I don't see much benefit in fullranges over properly designed coaxes
nas
Most cheap are like this:
And no one will convince me that it will have good tweeter range.
This one is the cheapest I would bet my money on. It is used on some 5-10k EUR speakers...
~130EUR
130EUR is SB NRX2 6 inch range + decent tweeter
jaakkopetteri
You seemed to talk about small coaxes in general, not just dirt cheap ones. I do agree that full-ranges are better value for the cheapest builds.
I haven't even heard the Omnes but specs-wise, I would take it over most small full ranges.
BTW, you can find the Sica coax for 87€ here
Reactions: nas
nas
T.y. Haven't heard about this eshop. Yes, there are some other places with ~90EUR pricing indeed. That coax became much sweeter ;)
nas
Really? Like what :D
No, seriously, like what
Are we on the same page?
I was talking about speaker drivers. You mentioned KEF because they build speakers (drivers + cabinets) or second hand speaker drivers from those cabinets?
Ardacer
I meant used/replacement drivers from kef. But be careful with coaxials, of any kind. They like to die if you are not carefull.
nas
I do not like both ideas: to buy used or to buy new replacement OEM driver for some specific box. Both are way too problematic.
