Sokel
- Joined
- Sep 8, 2021
- Messages
- 11,652
- Likes
- 12,929
I think that's the one:You will not find it, not for the misterious KY series 63V 2200uF
Scroll down and try to find the 63V 2200uF reference. You can check at nippon semi-con website as well.
That's strange.Scroll down and try to find the 63V 2200uF reference. You can check at nippon semi-con website as well.
LCSC is the only reputable supplier that sells them, but even they fail to provide a valid datasheet. I have a bunch being shipped to me at the moment. Asked them for an explanation but they haven't answered yet. My current hypothesis is that it is (was) a custom reference, but as of today, it remains misterious to me.That's strange.
Mouser also has KYB,KYΩ and KMQ at that values but not KY.
On the other hand there's a gazillion knock offs at Ali and the usual,I don't know that the heck they copied.
However Fosi has showed in previous time that uses original stuff.
which means that the lifetime is approximately halved for every 10°C rise in ambient temperature.
This is just one factor only.Regarding heat the product data sheet shows that its running well inside its limits.
Personally I would not ignore anything alarming but everyone has their own choices and preferences. It is already a lower cost product with decent performance and highlighting the experiences or anything alarming should be seen as something to be improved upon in next iterations.No need to fear the device exploding in flames.![]()
Very cool setup. Could you please do some measurements before and after adding thermal paste on the monos so we can see the difference in temperature it makes?
I have done this, but I only measured the outside case temperature. You can see my previous post to see the temperatures before adding paste.
The short version is that adding paste made no difference in the external temp of the case.
Having said all of that, I'm not convinced adding paste is needed.
Heat dissipation is not only about the chip itself.
Have a look at the pic below:
Caps are directly above the heatshink area.Now go to cap's datasheet and see how their life span varies with temperature.
One must also consider resistor's ppm (the better quality-the lower),etc.
We must look at the device as a whole and it's usually the weak links to pay attention first.Chip is not this link.
LCSC confirmed customized part. All specs are identical to the 1800uF version.LCSC is the only reputable supplier that sells them, but even they fail to provide a valid datasheet. I have a bunch being shipped to me at the moment. Asked them for an explanation but they haven't answered yet. My current hypothesis is that it is (was) a custom reference, but as of today, it remains misterious to me.
I did not bother with the paste, but noted the heat sink to case interface was a relatively large chunk of metal and bolts more or less directly to the case. Good contact took negligible effort and I tightened the screws down until it felt like a single piece.I have done this, but I only measured the outside case temperature. You can see my previous post to see the temperatures before adding paste.
The short version is that adding paste made no difference in the external temp of the case. This may not be intuitive to everyone, but there's a good chance the chip is running cooler even though the case temp is unchanged. Average external case temp, under steady state conditions, is directly related to energy the chip is dissipating and not the temperature of the chip itself. In a situation where the conduction is poor, the chip will run hotter to "force" the energy through the higher thermal resistance interface. When the conduction is good, the chip will run cooler since is "easy" for the heat to transfer to the case. In either situation, the amount of energy is transferred to the case is identical so its temperature remains the same (again all things being equal). If the room temp changes or you add a fan, then the case temperature will change since its thermal resistance has changed to transferring heat away from itself. In steady state, the chip will run a constant temperature above the case. Improving the thermal interface (adding paste) will reduce this delta.
Having said all of that, I'm not convinced adding paste is needed. I did it since I was opening them up for my own entertainment. For people who don't want to open their units, just use a 2mm hex to insure the two bottom heatsink screws are moderately tight and enjoy using the amp.
I am hoping one could not actually fry an egg on these if they were bigger! ...Reporting I got my two V3s, as well. The sound great and I cannot hear any difference between them and my Atoll IN 300 (which I love) Probably, if I had some device to AB test properly, I might hear a different...
I am using the V3 behind a minidsp Flex to power Dynaudio Heritage Specials, not so easy to drive.
Now I am in a bit of a mess because I actually only got them to prove that AB is better than Class D... now what?
I also got 4 Sparkos Op Amps but I have never worked with Op Amps before and don't really know what to expect nor whether I will need them. If anyone is interested I can write if I can hear a difference when I replace 2 or 4.
Yes, they are hot, not warm. If they were bigger I could fry an egg on the surface. But since I don't intend to hold them in my lap any I do not listen to loud music, I guess I will be fine.
One thing is already very clear - it definitely was not a waste of money. Amazing what Fosi can do for this money.
Well, as far as comparisons go, I did try one interesting thing, which was to swap one of my V3 Monos out for a ZA3, and I used the volume knob on the ZA3 for volume matching (gain on V3 Mono is lower than on ZA3) and no matter how I set it (stereo mode or mono mode), I could not get the system to sound right with a ZA3 driving one channel and the V3 Mono driving the other channel, so there is ABSOLUTELY a difference in how the two amps sound compared to each other. The difference is extremely clear and obvious.I am hoping one could not actually fry an egg on these if they were bigger! ...
Still waiting for mine - finally departed from sort facility mainland China...
I think comparisons with other amps are interesting, including (especially) when you don't hear a difference. A lot of the comments here are regarding bias, where one perceives a difference (perhaps price or whatever subjective reason) ... rather than when one doesn't. I'd be interested in your comparison with op amps because at some point I intend to do likewise, but I think A/B'ing is essential or we will end up in the usual op amp debate merry go round. The Fosi monos could allow a/b comparisons without an addtional device.
What we need is a methodology that might generally be agreed upon. I'd be happy to not hear a difference.
As is the perception of difference due to bias.The difference is extremely clear and obvious.
Interesting. I would expect the volume control being active on the ZA3 side to influence too.Well, as far as comparisons go, I did try one interesting thing, which was to swap one of my V3 Monos out for a ZA3, and I used the volume knob on the ZA3 for volume matching (gain on V3 Mono is lower than on ZA3) and no matter how I set it (stereo mode or mono mode), I could not get the system to sound right with a ZA3 driving one channel and the V3 Mono driving the other channel, so there is ABSOLUTELY a difference in how the two amps sound compared to each other. The difference is extremely clear and obvious.
-Ed
This was not a bias issue. I think you’re misinterpreting what I am saying. My point is that when using one model amp on the left channel and a different model amp on the right channel, even after volume matching the two sides, there is a clear and obvious problem with how the system sounds. Try, for example, having the speaker cables attached (accidentally) in reverse terminal order on just one side with the same amps (so one speaker is out of phase), and you’ll notice a clear and obvious problem with how the system sounds. I experienced a similar effect when I tried using V3 Mono on one channel and ZA3 on the opposite channel and then volume matched. It was very clear and obvious that there is a mismatch between left and right channels.As is the perception of difference due to bias.
I don't get how people who've been around here a while still say "it was an obvious difference so it must be real"
Bias or insufficiently accurate level matching are still likely explanations for what you are hearing. Especially if you were listening to them as a stereo pair, rather than AB comparing.
Although it is also possible that a FR variation due to the frequency/load dependency of the ZA3 without PFFB could also be responsible. Especially if your speakers have very peaky response.
How did you level matched them?This was not a bias issue. I think you’re misinterpreting what I am saying. My point is that when using one model amp on the left channel and a different model amp on the right channel, even after volume matching the two sides, there is a clear and obvious problem with how the system sounds. Try, for example, having the speaker cables attached (accidentally) in reverse terminal order on just one side with the same amps (so one speaker is out of phase), and you’ll notice a clear and obvious problem with how the system sounds. I experienced a similar effect when I tried using V3 Mono on one channel and ZA3 on the opposite channel and then volume matched. It was very clear and obvious that there is a mismatch between left and right channels.
How are you calling it bias if there is absolutely zero question that you could blindfold me, set up one room with two V3 Monos, and then a second room with one V3 Mono and one ZA3 (again, volume-matched), using identical speakers, and I am perfectly willing to bet my house that I will be able to tell you which room has matched amps and which room has mismatched amps? I never said I could tell which amp is on which channel, I said I could tell the amps are mismatched, that’s it. There are a number of perfectly logical and reasonable causes for this, such as slightly out of phase sound because of mismatched circuitry, design. Where is the bias in this? I find that insinuation insulting.
-Ed
