early rejecter
- Joined
- Dec 21, 2023
- Messages
- 130
- Likes
- 141
I keep mine in Auto on/standby which has worked well with no thump when coming out of standby.Anybody else figure out a solution?
Pop output to speakers.What kind of pop is scaring everyone? Is it from the speakers? Mine don't “pop” but they “click” from what I assume is the relay turning them on and off. I keep mine in auto mode and there has never been any sound that was alarming to me, it’s the same “click” sound that my receiver makes when it cycles power.
Yes mine was more like a loud, electric sounding click. But it definitely had to do with shutting down both amps using a power strip, as opposed to turning each one off separately using their respective switches. When done this way, no more clicks, pops, or any other scary noises.What kind of pop is scaring everyone? Is it from the speakers? Mine don't “pop” but they “click” from what I assume is the relay turning them on and off. I keep mine in auto mode and there has never been any sound that was alarming to me, it’s the same “click” sound that my receiver makes when it cycles power.
Hi. I’ve just got the v3 monos having had the v3 stereo for a while. So far honestly I’m not hearing a huge difference, both sound very good but it’s early days. What I definitely have noticed is that the monos are quieter than the stereo version, very noticeably, which I didn’t think would be the case. Got the 48v/10a split power block & monos are set to 31dB gain. Stereo has the 48v/5A power block & it’s set to max volume.
This isn’t a huge deal as both plenty loud just interested in what the reasons might be & if others are hearing the same? Is the gain lower on the mono despite having greater power?
Interesting. Didn’t know that affects gain. Is it a bit like reducing pre gain to avoid clipping? Is that how it levels the response? As you can tell I know very little about this.It could have something to do with the V3 monos having PFFB (post filter feedback) while the V3 stereo does not.
Any negative feedback, in theory, can result in reduced gain.Interesting. Didn’t know that affects gain. Is it a bit like reducing pre gain to avoid clipping? Is that how it levels the response? As you can tell I know very little about this.
Thanks. This is what I would have expected. The volume difference I’m hearing is pretty clear, but I’ve got an amp switcher arriving today so should be able to a/b test without the cable changing. I’ll report back.I saw one post saying that amplifiers with PFFB require a little higher input gain than non PFFB amps. Sorry I didn't save it, but it does make sense.
I did a quick and unreliable test here earlier today with my V3 Monos vs a V3 stereo. On my desktop setup with Sony SSCS5 speakers, I did not notice any difference. On my main system with Klipsch Heresy IV speakers, the V3 Monos seemed to be slightly louder. Neither stood out as being very noticeable. Auditory memory can't be trusted so who knows? There definitely wasn't a night and day difference between them.
It would be nice if someone with expertise about amplifier types could explain the differences.
Well. I did say it wasn’t the biggest deal no need for that. And volume control is irrelevant if set to max. The specs state the gain of the mono should be higher than the stereo so…something is not operating as it should be?I’m guessing it has something to do with one having a volume control and different gain :shrug:
Ok so mystery solved. I asked Fosi support and they got me to check the labelling on one of the resistors. Turns out I have the “updated” version with 19/25dB gain instead of 25/31dB, but the labelling on the rear panel hasn’t been updated. I don’t know why they made this change or if anything else was affected.,Thanks. This is what I would have expected. The volume difference I’m hearing is pretty clear, but I’ve got an amp switcher arriving today so should be able to a/b test without the cable changing. I’ll report back.
fosiaudio.com
