You should upgrade or use an
alternative browser.
P
I did not bother with the paste, but noted the heat sink to case interface was a relatively large chunk of metal and bolts more or less...
P
My preamp is a MiniDSP 2x4 HD. This gives me full EQ/correction/levels/crossover and volume control. I'm using optical input. The...
P
I watched Dune Part 1 with the volume high (reference levels) using my monos and after 3 hours they were only a few degrees warmer (48c)...
Loading…
Loading…
