I would agree - I see multiple 'religions' in audio, e.g. the subjectivists and the objectivists or the 'retro' analog lovers and the digital lovers.May I suggest that you (Fosi) make two different products? There is a reason why Schiit makes the Magni AND the Vali and sells them both.
1. Preamp with tubes.
2. Preamp with no tubes.
Then tube-lovers and tube-haters will each have reasons to your products.
The V3 (as the Aiyima A07 before it) sort of sits in that perfect space where it's cheap enough for everyone to buy and it both measures well and the subjectivists / YouTubes love it e.g. "The British Audiophile" gave the V3 a glowing review the other day - very unusual for him for something this 'cheap').
So because the V3 appeals to both 'camps / religions' what goes before it can be more complicated.
For the retro analog lovers (and mostly subjectivists) - I would could easily see a tube pre-amp maybe with a phono input as well as RCA and possible headphone Jack. This way they can have their 'tube sound' and possible a turntable and other devices further up the chain. Probably with Bluetooth and bass / treble tone controls. The 'concept' of this 'pre-amp' is to introduce that 'warm' tube sound into the mix.
For the digital lovers (mostly objectivists I would believe) - I would see a Fosi Device that is effectively a DAC, ideally with some more advanced EQ / PEQ than basic tone controls (see below). The 'concept' of this device i.e. 'pre-amp / dac' is to preserve a clean signal without any colouring. I would suggest a headphone output here also but no bluetooth as this side of the religion probably would only like lossless digital inputs and would ideally get that via whatever was connected to the DAC via USB/ Opt / Coax etc. A remote would be required to control the inputs and volume.
FYI: At the same time as receiving the V3 I got an alternative TPA3255 Amp the 'Wondom Bru5' - it is not as clean sounding 'out of the box' but because it has built in DSP it can be made to sound much better IMO - there is a thread about it here - it is not without its problems but when 'configured' it works very well:
wondom bru5 pc dsp configurable TPA 3255 "300w x 2" mini amplifier
https://www.aliexpress.com/item/1005004895645420.html here is their web https://store.sure-electronics.com/ but screwed if i can find it it looks like this company is more geared towards arcade, gambling and professional setups here's a screen cap of their software which gives you a taste...
www.audiosciencereview.com
Combine this type of advance DSP / PEQ capability with a DAC and feed the result into a V3 and I think you would have a very appealing product.
