Focusrite Scarlett 6i6 2nd gen measurements
Matias
São Paulo, Brazil
I am totally new to doing loopback measurements in REW, this is my first try, so please correct me if there is a better way to do this.
I have a Focusrite Scarlett 6i6 2nd generation audio interface and connected the Output 1 line out into the Input 3 line in using a 1/4" TS cable with about 2 meters (7 feet) that I have here. Using a 1 kHz sine wave full scale and set the monitor level to the max.
I tried to compare the difference between the stock switching mode power supply (SMPS) and the iFi iPower SMPS.
While measuring I noticed the noise floor raised and lowered with ambient noises. :oops: I tried closing the doors and windows and grab the screen shot in best moments, but microphony definitely has been picked, specially between 80 to 300 Hz.
Questions:
1. Is there a better way to measure without picking up microphonics? In the middle of the night maybe?
EDIT: fixed here https://www.audiosciencereview.com/...tt-6i6-2nd-gen-measurements.12761/post-379502
2. Are these lots of harmonics OK? I found this to be quite noisy. I expected around -100dB some 2nd and 3rd, sure, but not the higher ones.
3. Any settings in REW I should use to improve these measurements?
RayDunzl
Central Scrutinizer
Riverview FL
What happens as you reduce the tone level?
I think REW throws some harmonics unless you back it off a little.
(Maybe it was an earlier version... Not seeing it today.)
naagratrax
France, Paris
Questions:
Are you happy mate with the iFi iPower SMPS ? i seen a post from Amir in 2018 that it's make no difference with the stock psu
RayDunzl
Central Scrutinizer
Riverview FL
I have a Clarett 4 Pre USB
REW 1kHz -0.90dBfs -> USB -> USB Playback 3 -> Output 3 -> guitar cable -> Line Input 7 -> USB Input 7 -> REW matching your -7.17dBfs
Look familiar?
-3.30dBfs source at REW
There's no "volume knob" in this path, though.
LTig
Europe
Questions:
Repeat the test and knock on the TS cable, does this change the noise floor? If yes much more than ambient noises? If yes try another cable, preferably a balanced one.
Matias
Matias
São Paulo, Brazil
I deleted my previous post because it was wrong.
I am using volume knob at maximum, which I measured with a multimeter 2.0V between tip and sleeve of the cable.
Now measuring with -12dB on the generator things are a lot cleaner too.
Matias
Matias
São Paulo, Brazil
Yes, knocking on the cable, the table or even speaking loud the noise floor rises.
I wish I had a short 1/4" TRS here to test but I don't... Would have to order it specially for measuring.
Matias
Matias
São Paulo, Brazil
Look familiar?
Interesting. I was looking into upgrading my interface to a Clarett 4Pre USB.
Are you using the same configs I set on the right of my prints, with FFT length and averages and window the same?
LTig
Europe
Disconnect the cable and knock on the table or speak loud.
RayDunzl
Central Scrutinizer
Riverview FL
Probably not... Just wanted to show the harmonics ADC likes to create at higher input levels, and matching your levels.
Let me look again.
Matias
Matias
São Paulo, Brazil
Yes, it picks up microphony... Specially around 80-300Hz.
Matias
Matias
São Paulo, Brazil
Here are some multitone measurements with stock and iPower SMPS.
Generator I used the following settings, just before clipping.
Matias
Matias
São Paulo, Brazil
How high does the noise floor rise, cable disconnected?
This is multitone with all cables disconnected. How come it still measures something??
Focusrite Scarlett 6i6 2nd gen - iFi iPower SMSP multitone all cables disconnected.png
Matias
Matias
São Paulo, Brazil
I am very impressed how much microphony picks up on an unbalanced cable. And here is a quite room. I can only imagine how much noise a guitar amplifiers picks from a guitar cable on a live concert! o_O
Edit: forget this, I left a microphone connected, stupid mistake.
LTig
Europe
The real problem is that even an open (not connected) input picks up microphony. Next step would be to short the input.
Matias
Matias
São Paulo, Brazil
Thanks! You nailed it. I had inputs with no cables but I left them out to the monitors, this was causing the microphony! :facepalm: I told you I was noob. :)
Edit: even worse! I had a microphone plugged into input 1. This was routing to the monitor outs. This explains a lot, including my stupidity. :D
Here are the multitones with no inputs enabled.
No other inputs to the monitor outputs, just the software signal.
Matias
Matias
São Paulo, Brazil
Now for reference, with the noise generator 1kHz at full scale, the volume knob at 10 o'clock which would be a good listening level for me, this is how they both measure. Extremely low distortion below -130dB or so. Noise from the power supply is dominating.
I guess I should stick to my 6i6 2nd gen and skip the Clarett 4Pre USB then. :)
And multitone.
Focusrite Scarlett 6i6 2nd gen - iFi iPower SMSP volume 10 oclock multitone.png
Matias
Matias
São Paulo, Brazil
And to fix the first post, this is the 1kHz full scale signal into maximum volume (2.0V) monitor out with no inputs enabled.
