Focal Aria 906 Speaker Review
Hi,
I’m looking for information about lighter-colored grilles for the Focal Aria 906 and CC 900 speakers.
  1. Are grilles in lighter colors available for these models?
  2. Can they be purchased separately, or are there third-party options?
  3. Are there any alternative solutions for getting lighter grilles, such as custom fabrication?
Would appreciate any insights or recommendations.
Thanks!
Hi,
Thanks!
It doesn’t look like there were lighter color grilles for the older Aria line, just the Vestia line.
Custom fabrication is easy for any seamstress/dress maker or even doing it yourself.
The frames are the proprietary element so you will either need to sacrifice your existing grilles or buy replacement ones as donor units, or attempt to over wrap your existing grilles with an additional layer of fabric.
Unless you measure it, there is no way to know the impact of two layers of fabric although I suspect the differences will just be a tiny bit of attenuation and no real audible difference when level matched. Most of the effect of the grille is from the frame in my opinion.
Agree with @GXAlan and will add a friend had a wood shop do grilles...eh. Next try he had his picture framer do it, someone who is used to stretching fabric (canvas) all day. Came out much better. Good luck! Or, just take your grilles to a tanning salon, bleach them with UV...
I got them new for very low 660 euro price, I love them. Go gdt them if they are ok.
The midwoofer is NOT made out of flax seeds. It incorporates flax FIBER. Flax has been grown as a textile crop for at least 10,000 years. The fibers are used to make a fine cloth which is known as LINEN. Only recently have people been interested in eating flax seed oil, because it is high in omega 3 fatty acids, considered by some to be a useful nutrient.
As of today, are these speakers still worth it? I found a new pair for 900€ as well as a new pair of the Chora 816 for 780€ and I am hesitant about which one to get...
I read a lot about both when the price gap was larger (and both prices higher), chose the 906, never regretted it.
There are new competitors that have emerged in the past five years, for example: https://www.audiosciencereview.com/...s/ascilab-f6b-bookshelf-speaker-review.63387/ but if you need the output of the Chora, that would be a fine choice. Not quite as accurate/neutral/controlled, but more bass and higher output capability.
Anyone who has had these for a few years, how is the "leather" front holding up? I assume its not actually leather but some sort of vinyl.
I'm a little leery of electronics which use "soft touch" materials like this. If they get it wrong the material breaks down over time into a sticky mess. I had a pair of the original Paradigm A2 powered speakers who's front got so bad I had to get rid of them: they got so sticky that they were impossible to clean, and while using alcohol did get rid of the tackiness, they looked an absolute disaster as a result. Same thing happened to a Grundig radio I had a while back.
It holds up well. Quite hard to clean however, as mine had a very thin layer of very fine dust built up and it is harder than I expected to clean it up.
Sold mine though
