experiences measuring Lyngdorf SDA-2175
dougi
ACT, Australia
After recently discovering this forum (and others) I decided to start measuring my own system, with interesting results!
Given this is the amp forum I will focus on my TacT/Lyngdorf SDA-2175, a 13 year old switching amp, well regarded at the time but no measurements published. (there was one review with some on the SDAI2175 integrated but none on the power amp).
I constructed a 200W 8 ohm load last weekend which went well. I won't go into all the travails, but after measuring a class AB amp ok (Krell KAV-300i, 20 years old) trying to measuring an amp with common mode voltage on both speaker outputs was tricky. I ended up making an RCA to XLR cable using +ve and -ve only (no shield/ground) into my audio interface (Scarlett 2i2 gen2) from the test load sample point so it was differentially measured (with no connection to ground). This picked up a lot of 50Hz products. I added a (cheap) isolating transformer which improved things from a noise point of view, but ended up adding a lot of low frequency distortion. Anyone with how to measure with this common mode voltage present better I'm all ears!
I was mostly happy with the results though, using the 2i2 with REW with a 192kHz sampling rate. The amp driven directly from the 2i2 balanced output, and back into the balanced microphone input. To summarise results, single channel driven :
1kHz THD: 0.1W 0.015%, 1W 0.03%, 10W 0.06%, 100W 0.07%, 150W 0.08%, 200W 0.1%, 230W 1%. The load survived OK! Third harmonic dominated.
20kHz THD: 0.1W 0.08%, 1W 0.04%, 10W 0.04%, 100W, 0.07%, 150W, 0.13%, 200W 0.13%, 230W 0.14% (I ensured they included up to 96kHz)
CCIF IMD 19/20kHz: 1kHz difference tone 1W 0.0006%, 10W 0.0019%, 100W 0.023%, 130W 0.023%, amp started protecting itself after that! (Actually looked horrible on the plot at 100W with lots of products including above the band around 60kHz only 35dB down).
S/N ratio A weighted ref 200W: 100dB A weighted, (20 Hz to 20kHz filtered) but limited by the audio interface. (amp floor was about 1dB above interface noise floor so if you do the calcs the real S/N >105dB A weighted)
Frequency response into 8 ohms (measured without the isolating transformer which was not flat): wrt 1kHz, -0.2dB@20 Hz, +0.5dB @20kHz, -3.0dB @35 kHz.
Conclusions:
It certainly gets to the power spec, clipping >230W. Distortion somewhat higher (but measured differently), just OK and perhaps influenced by the isolation transformer used. Distortion is flat at least and less @ 20 kHz. S/N OK but limited by the other noise being picked up and of the 2i2. frequency response similar to spec . In practice it should sound quiet and clean, not edgy and never clip, under my listening conditions.
To compare with the older Krell KAV-300i 1kHz THD was as low as 0.017% at 1W, 0.023% @ 100W, 0.04% @ 150W, clipping @ ~200W. THD @20kHz @150W 0.5%. CCIF OK at low power but took off before 100W (0.02% @ 50W but 0.68% @100W). S/N about 105dB A weighted (20Hz to 20kHz limited) reference to 150W (nominal rating). This was the good channel, after rebiasing. The other got a bit bad when hot to around 0.15% at 1W @1kHz, despite rebiasing it.
Any feedback gratefully received! I enjoyed doing it and didn't blow anything up which is a good start. I did accidentally ground the speaker terminals once, but all was OK. I want to give it another go if I can work out a better way getting around the 35V on the terminals.
ichonderoga
Quoted specs are in the attachment.View attachment 69967
Conclusions:
Awesome. I've had this PWRAMP since around 2009 and still love it. Great to see some measurements. My feedback would be this: Pictures (and Tables) make for easier and greater understanding of the measurements listed - "A picture is worth a thousand words" :)
dougi
dougi
ACT, Australia
Yeah, when I measure it more accurately i'll do a better job with presentation.
ichonderoga
Have actually thought about replacing this with a Benchmark AHB2 but your measurements just gave it another lease on life
dougi
dougi
ACT, Australia
I had been thinking the same. I have a DPA-1 as well, with Roomperfect and was also considering replacing both with the Anthem STR integrated.
ichonderoga
... man the aesthetics on those look similar - Any lineage?
Hephaestus
Rapture
Lyngdorf´s current design language is from 2013 or so when CD-2 was released. Every device since then has carried same DNA. Anthem STR was released much later.
dougi
dougi
ACT, Australia
Yeah, don't they? Here in Oz the slightly older Lyngdorf TDAI-2170 is $6500 and the Anthem STR integrated is $6999. Given the strangeness around the fully digital amp of the TDAI (as evidenced by Amir's measurements of the TDAI-3170) if I do replace the DPA-1/SDA-2175 it will be with the Anthem. After experiencing good bass management and room correction I cannot go back.
ichonderoga
Anthem isn't a brand that's available here in Denmark, so don't know them. Either way I'm a Pre-& Pwr-amp (as separates) kinda guy ;-)
+ after finding this site 1½ years ago I've become obsessed with great measurements - I'm in it for the great numbers :)
dougi
dougi
ACT, Australia
Take 2! I have had another attempt at measuring this, after assessing ways around the 37V DC common mode voltage problem on all speaker terminals. Unlike Audio Precision kit, which copes with 230V common mode (must use an instrumentation amp like an AD629) a regular differential amp in a sound card will only cope with 10V or so. I ended up putting high pass filters in on both + and - to ground. This now worked well but with slight bottom end rolloff. The results are much more like the Lyngdorf spec for distortion now. All measurements using 192kHz sampling.
Frequency response
Distortion at 1W vs frequency
Distortion @ 10W vs frequency
Distortion vs power level
CCIF 19/20kHz @ 10W total power
Noise spectrum, 1kHz tone 1W
Notes and observations
One channel is worse for distortion at low levels, but still meets the spec (0.004% @ 1kHz @ 1W or 88dBc). Right channel very good ~100dB @1W most frequencies. Distortion well controlled until 200W (<0.03% or 70dBc). Despite the L channel having worse THD, the CCIF result is better. This beta version of REW also couldn't calculate total THD sometimes (giving falsely high or infinate results, but the curves are correct).
I haven't included the THD+N curves as REW gives very high results which likely don't align with the Lyngdorf measurement method.
SNR was corrected for both 1W->200W and adjusting for the audio interface noise floor (only 1.5dB below amp floor). Doing these corrections gave 115dB @ 1W A-weighted, close to the spec of 117dB.
The amp is still going strong and meeting the specifications. Not state of the art any more but good. No need for me to upgrade it :(.
ichonderoga
Absolutely brilliant! I'm very happy to see that the performance is this close to spec. The two things that catch my eye is also what you point out which is the THD and its imbalance between channels. Also really cool to see how close to spec it is when measuring wattage. That said I'm keeping mine until I've saved up for the Benchmark AHB2. Thanks @dougi keep being awesome!
Kimkruse
Anthem is imported in Denmark by Interceptor.dk
