spend some time learning how to actually measure and modify a room to meet a set of design requirements. it will make much more of my commentary relatable and understandable vs someone who has not done so.
Have you posted any measurements here?
No, he says to buy a speaker with proper off-axis response that correlates well with direct sound.
If you chase and try to remove all those reflections for a bad speaker, you will build a padded cell that will be dead as a year old fish. It will sound horrible for any 2-channel listening and depending on how far you have gone, for multi-channel as well. You have completely bastardized Dr. Toole's research with that statement.
no, he states if the loudspeaker has poor off-axis response, the reflection will color/tonal change the perception of the direct signal - and in that case it is best to absorb the reflection and to do so with broadband absorption that doesn't modify the spectral content of the reflection (ie, fully attenuates it).
and if you have a loudspeaker with good off-axis response, then it is "a matter of taste" whether the user prefers more accurate, pin-point imaging (attenuated first order high-gain early reflections) - or a more broadened width imaging as with natural sidewall reflections allowed.
500 Hz? What was explained was a general issue with ETC because it is spectrum-blind. It says that the spikes in such measurement are not representative of the true energy of the reflections. There is no magic 500 Hz in there. Anything that absorbs some of the spectrum of the reflection will produce such false measures.
You do? In literally years of arguing with you on this topic on AVS, you did not once produce a measurement you had performed. Later on I discovered you lived in an apartment and did not even have an audio system.
And why do you need ETC to know which reflections to absorb? If you are designing a new listening space, how would you do that without measurements? You need ETC to know there is a side wall reflection? Ceiling? Floor? Rear and front walls?
Answer is that you don't. Professional acousticians design state of the art listening spaces all on paper without a single measurement to "find reflections: using ETC or otherwise. We use psychoacoustics research into perceptual effects of reflections and use that a priori to decide what to do with reflections. ETC with its faulty amplitude problems need not apply.
This forum is so hell bent against acoustic treatment lol. Even the writer of the bible has a lot of acoustic treatment in his room, including absorbing the first sidewall reflection.
This room? https://www.thescreeningroomav.com/...te-Real-World-Home-Theater-and-Listening-RoomThis forum is so hell bent against acoustic treatment lol. Even the writer of the bible has a lot of acoustic treatment in his room, including absorbing the first sidewall reflection.
Maybe he needs to publish a "Sound Reproduction - For Dummies Edition".
Am I a follower? Let's not forget that there are many less vocal members here that are just a little less vocal. This is a site for the exchange of ideas and I hope all ideas are debated on their merits. I especially am interested in the relation between directivity (i hate the term) and imaging. To sound absorb or not?I don't think that will work. The followers have already seen what they wanted to see and are taking the religion in a different direction.
What we actually hear is that jarring discontinuity between drivers radiation patterns if I understand the topic .
you can’t just shove good drivers in box and call it a speaker it won’t perform acoustically
That, and lobing.
Exactly. In fact, if you'll indulge me in an unscientific generalisation for a moment here: A well-designed speaker made up of crappy drivers will tend to sound much better than a poorly-designed speaker made up of SOTA drivers.
Surely it is more likely to be the bass driver breakup than mid at that frequency?Maybe you are right. Here are a couple of CSD plots:
Sorry, my pitiable brain read 350Hz up thread and I see on the graph it is 3.5kHz.Those are measurements of the SM75 midrange driver.
Here's the CSD plot of a SCM100SE:
https://www.hifinews.com/content/atc-scm100se-loudspeaker-lab-report
There used to be a paper on the net iirc by K&H before they became part of Sennheiser that illustrated how good their mid dome was using a comparison with a "well known mid range dome" (well known to be the ATC) showing an almost undamped breakup on it. This could be it.
Absolutely. It's a more or less non existent topic and blind spot in Toole's researchers. However, it's been researched by others. But most are ignorant of past and other studies and cherry pick what suits them.i agree. i inquired numerous times at AVS and he was kind enough to respond and is very forth-giving that it is simply a matter of taste. and that certain people (professionals, studio engineers) would perhaps prefer a more objective (accurate) response for reproduction (for both working and pleasurable listening) than others that would subjectively prefer their own tastes (vs use of polls are surveys) - all very valid conclusions.
and as you reference, there is seemingly almost always a complete lack of discussion on the later-arriving sound-field in such circumstances. many will "remove" lateral energy via attenuation of first-order sidewall reflections, but completely ignore the re-introduction of that later energy via the use of 1-dimensional phase grating diffusers to provide a very dense, lateral reflection-rich diffuse tail to provide a sense of spaciousness and envelopment (coming from the rear wall/rear side wall directions) - whose decay also emulates the linear slope found naturally in large acoustical space reverberant sound-fields. you get the best of both words: a large ISD where-by only the direct signal is allowed to be "heard" (increasing the acoustical perceived size vs what the room's natural boundaries allow), increasing accuracy of direct signal in terms of localization, imaging, and speech intelligibility - and then providing a sense of the room (and in fact a sense of a much "larger" room) via the sparse reflections being converted into dense, reflection-rich, diffuse reflections and their lateral direction for spaciousness and envelopment.
so the comparison and testing should never (in my opinion) simply be: "allow sidewall reflections vs absorbed sidewall reflections", it should be something akin to "allow sidewall reflections vs attenuated sidewall reflections with later-arriving dense, reflection-rich lateral diffuse sound-field". it's a completely different response and perception. you are removing some lateral energy, but re-introducing it to the listening position at a later-time (in a managed fashion).
I have considered the KH420 from time to time but have so much kit I like already I have managed to avoid spending the money so far.View attachment 63374
The K+H dome manages 10dB more max SPL than the ATC one in a smaller footprint too.
