Eversolo DMP-A8 Balanced Streamer/DAC Review
Rate this streamer/DAC/Preamp:
    Votes: 8 1.7%
    Votes: 12 2.5%
    Votes: 91 19.3%
    Votes: 361 76.5%
Hello everyone,
I apologize in advance if this is a basic question, but I would greatly appreciate any insights on an issue I've encountered with my newly purchased DMP A8.
I've connected the DMP A8 to my amplifier via RCA cables, and while the sound quality is excellent, I find that I need to set the amplifier volume to around 50-60% and adjust the DMP A8 gain to approximately -20 to -10 dB in order to listen to music from streaming services like Tidal at a reasonable volume. I don't mind these settings, but I'm curious if this is typical.
For context, I also have a turntable (Planar 1 connected to a Schiit Mani preamp and then to the amp), and with that setup, I only need to set the volume at around 25% to achieve a similar loudness.
Additionally, I've noticed that when streaming via Tidal Connect, the music is about 10-20% louder compared to playing the same tracks directly from the DMP A8. Has anyone else experienced this? What might be the cause?
Thank you in advance to anyone who can provide guidance on these matters.
More output ( twice as much) through the XLRs.
No, have you asked on the Zidoo forum?
Roon user here.
Roon user here.
nope, i might tho.
interestingly, tidal connect at -30db gain and 30% volume on amp = tidal on dmp at -20 gain and 50% volume on amp
I’ll play with the setup a bit more, could be a setting somewhere I’ve missed.
But, as I said, I don’t mind amping the volume as long as the sound quality is good
I have a zidoo UHD8000 and it is clearly a work in progress. It has the potential to be very good, but its Roon implementation thus far (in the latest beta) is faulty; no multichannel dsf support (everything is downmixed to 2 channels), despite it says its Roon Ready.
Only the Sub HDMI port(audio only) support multichannel DSD
Hi Mirror, I am using the sub HDMI port and it provides multichannel dsf when I use the internal zidoo music app and even jplay for ios. However, on Roon, I can't play multichannel dsf. Everything is downmixed to 2 channel. Don't even see option for 5.0 or 5.1 channel mapping.
Did you upgrade to 1.1.47? Switch to receive the beta version option. The multchannel Dsd supports for roon ready since v1.1.47
Yes I did. Please take a look at the attached regarding what I see on Roon. There is no channel mapping for 5.0 or 5.1. Everything seems to be downmixed. There are far fewer options than I remember when I used the A6
Did you try set the hdmi audio output to RAW or Auto? We tested some devices and no problem with multi-channel DSD for roon ready
Hi Mirror, I tried both RAW and Auto and still having problems playing multichannel DSD for Roon Ready. No difference at all between the two settings.
New firmware out, lots of feature upgrades including native Apple Music integration, which is super slick to be able to combine playlists across sources. It’s at “CD” lossless 44.1k though, you need to use the android/side loaded Apple Music app to play high resolution still.
This comment from stereophile A8 review site. What is he talking about Ultrasonic noise? Subjective by all accounts!!!! No testing has revealed this to be an issue.
My comment comes a bit late, I hope some will still find useful. I listened and tested (with my limited gear) both these models. And one confirmed the other, the A6 sounded slightly more coherent/I could make more sense of details and soundstage. While both units suffer from very high ultrasonic noise it is even more so true for the A8. My suspicion is that the volume control circuitry (absent in the A6) is badly placed and picks up copious amounts of noise from surrounding digital circuits. Both units use reputable DAC chipsets and frankly I expected better implementations. As positives one can appreciate the user interface which is quick and easy to figure out. But the rest sort of... reflects the price.
If one could here it, I'm out for that
:cool:
But besides, look at Amir's tests and you will recognize, that ultrasonic is filtered by setting a fitting filter, or is not, if filter is set to not.
What problem?
Reactions: EJ3
This comment from another review site. What is he talking about Ultra sonic noise?
Bollox and nothing? I didnt see that in any measured results from Amir, stereophile, etc. And i don’t know about you but i have pretty good ears and know i cannot hear 20k hz +.
And I certainly don’t hear any issues in my a6 or a8. Listening to the a8 right now with some Ornette coleman streamed off Apple Music at 44.1k lossless and it sounds really, really good.
A6 & A8?
Just curious...
In my office i have an old BAT Integrated amp (VK-300xSE) that I just had fully serviced by BAT, running some small harbeth p3esr xd speakers. I use the A6 as the source. I’d bought the A6 as an experiement to see if a streamer would work for me, really liked the device, features, and software.
When A8 was released i put that on my main system (luxman 509x integrated amp and harbeth 30.2xd speakers, yeah i like harbeth sound). I ditched my benchmark dac3, mac digital source and just use the a8 for digital now. I also have a vinyl front end. The A8 does everything i need for all various digital sources (mostly Apple Music lossless/high resolution and about 2500 or so CDs ripped lossless and stored on an internal 2TB ssd). It’s super easy to control and manage via my iPad or iPhone.
The latest update makes mixing and matching what you’re playing via the playlists really easy.
Can anyone confirm that, when connected to a TV using HDMI ARC / eARC, can the TV remove control the volume of this unit? The unit is not advertising HDMI CEC compliance, but I'm never clear on if that is required for the volume control if ARC is supported. Sounds like sometimes with eARC this is possible?
