renaudrenaud
Or E30: there is a remote!
I see. So something like the wxa-50 wouldn't quite cut it correct? It costs about the same as the a-s501 but I get streaming features with it, albeit less power, around 75W at 6ohms according to leave vs the 100w of the a-s501
Hello everyone, like most of you, I purchased these speakers after reading this article. In fact, I have had Elipson Planet L on their feet for two years. Due to their lack of bass and the fact that I cannot put a woofer in my living room, I was looking for bookshelf speakers with more bass.
I just made a first listen, I am a little disappointed for the moment because I found the mids and the highs a little garish, unlike the planets much softer.
On the other hand, the sound is more open, the sconore scene is larger but I find that hearing fatigue happens faster than my other speakers.
What are you powering them with? it sounds like there underpowered, I noticed they come alive with more powerHello everyone, like most of you, I purchased these speakers after reading this article. In fact, I have had Elipson Planet L on their feet for two years. Due to their lack of bass and the fact that I cannot put a woofer in my living room, I was looking for bookshelf speakers with more bass.
If you want any bass out of them give them as much clean power as you can! I’m feeding them 125w@8Ω off a keces s125 and the bass and sound is awesomeThat's what I said to myself, I stopped playing the hifi because of the kids for a few years, I'm starting to make a new system for myself. I bought a SHD minidsp two weeks ago. For the amp, I will soon buy one made from purifi.
So I have a small "Full Digital amplifier", which processes the digital signal from end to end, without DAC. This is the QLS QA100. It develops 100w into 4 ohms. I love the sound it makes, I compared it to 2/3000 euros amps, it was doing great . But it may be a bit light for these Elac ...
Your telling me a 100w peak power amplifier will sound the same as a 200w rms amplifier on the same speakers at the same volume ? The dynamic response of amplifier will have a huge impact on the soundA speaker only uses as much power as it uses. If the amplifier is able to supply more power than the speaker is using, this does not affect the sound, because that extra power is power that the speaker isn't using.
If peaks of music within 100W why not? Assuming all else being equal (noise, etc.).Your telling me a 100w peak power amplifier will sound the same as a 200w rms amplifier on the same speakers at the same volume ? The dynamic response of amplifier will have a huge impact on the sound
It depends on the application. Very large room, distant listening position, low-sensitivity speakers, reference-level volume, very dynamic material - the 200W should sound less terrible than the 100W (but probably still terrible). However, for near field listening it wouldn't matter at all. For something in between, you would need to actually measure several things to determine whether or not the extra 3dB of headroom makes a difference.
I agree it has to be the placement/room. I have never seen a review say they sound garish or bright. If anything they may be boring to some (my use of Dynamic EQ fixes that for all speakers when listening at lower levels).The Reference's are designed to be pretty neutral, if they seem bright it's most likely the room, speaker position, or other gear.
I currently have a harsh room even with cloth blinds, an area rug, couch and 2 chairs, and with the speakers not toed in. My ears are also sensitive to high pitches. The Reference's are just at the edge of being too bright in my room with the treble at 0.
For comparison I had my Paradigm Prestige 15B's treble at -7 in this room, but sounded great at 0 in previous better rooms.
Try adding a few more soft furnishings and having the speakers point straight ahead if you don't already.
Can we say that the speakers, just out of the box, need a little "break-in" to relax the membranes?
