Grooved
- Joined
- Feb 26, 2021
- Messages
- 682
- Likes
- 441
Thanks, just found it in the document.Grooved, Fig4 page 20
The rest of the Fig4 is OK for me, I see how SCLK and LRCK are generated, sent on GPIO 1 and 2 then to your I2S ports (if I'm not wrong, and with GPIO3 sending Data), but this top left part, as I understand it, it's only the XIN signal that can be sent on XOUT. Am I right ?
If so, XOUT pin would only work for 48/96/... SR
So I may need two wires to get both clocks, then a switch to select one of both.
I took a moment to place it under a laser scope, and not sure if it would be better to solder wires on the path or directly on the pin.
You think it's better on the path ?
