IVX
well, I'm not sure regarding Audiophonics but Sunny has it as APU cables(3.5mm to XLR male or 3.5mm to XLR female, also you can get "ADC probe" cables aka XLR male to 2 hooks In+/In- and one crocodile-clamp to GND).
Is the pin/connector ok? Scaler printout says + - G G, the cable I can see has + - G to XLR.well, I'm not sure regarding Audiophonics but Sunny has it as APU cables(3.5mm to XLR male or 3.5mm to XLR female, also you can get "ADC probe" cables aka XLR male to 2 hooks In+/In- and one crocodile-clamp to GND).
sorry, I don't understand your question..Is the pin/connector ok? Scaler printout says + - G G, the cable I can see has + - G to XLR.
The printout on the scaler shows 4 parts of the 3.5 mm connector (+/-/G/G) while the connector is the standard 3-parts (+/-/G). I guess it's all ok since the Ground is common.sorry, I don't understand your question..
Is "bundle 4", ADCiso on AliExpress a Grade 0 ?Cosmos ADCiso Grade 0, MONO mode reaches THD+N@1kHz -125db. I.e. peak of APx555b THD+N performance level. The sine source of proto of Cosmos DAC, Cosmos Scaler as a buffer with 0db gain, 10Vrms balanced output. Cosmos ADCiso Grade 0 was a random one, just first from the batch, not the best of Grade 0 at all.
The "GND" stands "Ground"The printout on the scaler shows 4 parts of the 3.5 mm connector (+/-/G/G) while the connector is the standard 3-parts (+/-/G). I guess it's all ok since the Ground is common.
yes, if any questions, Sunny is online all day.Is "bundle 4", ADCiso on AliExpress a Grade 0 ?
I was waiting for the Cosmos Scaler because of the low input impedance of the Cosmos ADC, and while the Cosmos APU solves this issue for 1kHz signal, I wanted to measure IMD, Multitone, etc. I finally got the Scaler and did a quick test. Let me share the results.
https://www.audiosciencereview.com/...ts-and-measurements.37739/page-3#post-1328586
I measured two DACs with Cosmos Scaler and ADC (Grade B). One is TOPPING D30Pro (Balanced) which did not have any problem with the input impedance of Cosmos ADC. The other is an ES9023 based DAC board (SE), which had high level distortion at low input impedance. Below is a comparison of without Scaler, with Scaler 0dB, Scaler Auto and APU 1kHz notch (THD+N and 1kHz signal dBFS at 4.5V input range). The input range of Cosmos ADC was all 4.5Vrms, measured by Stereo mode of ADC (not MONO).
As you see, Cosmos Scaler reduced harmonics of the ES9023 DAC drastically. Without Scaler (Red) vs with Scaler 0dB (Green).
I was able to measure IMD (SMPTE 60Hz and 7kHz) either by 0dB or Auto settings of Cosmos Scaler.
While the Auto setting of Cosmos Scaler was unstable when measuring multitone. 0 dB (or fixed gain) worked fine.
I am satisfied with these results. Thank you @IVX for this nice variable gain input buffer.
I bought their previous HS ISO $100, and that was absolutely useless due to 5000pF(Cosmos ADCiso 8pF i.e. 625x times better) of the barrier capacitance.Has anyone tried the Hifime High-Speed USB Isolator v2 with the non-isolated Cosmos ADC? It's reportedly using the same AD UM4166 as the Topping HS02 isolator, but only supplies up to 500 mA of current. (And it's cheaper.)
Thank you, pls try to compare DR(THD+N@1kHz -60dbfs A-weighted) tests, ADC vs ADC+Scaler(gain +20..+26db). ADC+Scaler outerforms APx555b for 7db in the DR test of Meizu HiFi DAC.I was waiting for the Cosmos Scaler because of the low input impedance of the Cosmos ADC, and while the Cosmos APU solves this issue for 1kHz signal, I wanted to measure IMD, Multitone, etc. I finally got the Scaler and did a quick test. Let me share the results.
A battery-powered laptop is good enough too.I think a big part of it has to do with the DC-DC converters used to provide power across the barrier. Using a separate DC supply, like what's done on the ADCiso, is a way better idea. But, people want convenience and low price more than they want performance, so that's what we get.
Absolutely, but that doesn't work with some software (ADC on one computer and source on the other). Plus you need another computer! Isolation is less expensive overall - see; we want low cost - and takes up less space.A battery-powered laptop is good enough too.
As user MC_RME writes in the post I linked to, he measured the capacitance of the new, v2, high-speed, €57 version to 71 pF. So only 10x worse than ADCiso. (Do you have a rough idea of the amount of capacitance a laptop running on battery presents to the audio source?)I bought their previous HS ISO $100, and that was absolutely useless due to 5000pF(Cosmos ADCiso 8pF i.e. 625x times better) of the barrier capacitance.
I think you can use a battery-powered laptop to break the GND loop.
Well, I've ordered a Cosmos ADC Grade B + the Hifime isolator now, so in a week or so we'll know if it works or not! Cost (including shipping for the isolator and 25 % VAT): €305, compared to €343 for the Cosmos ADCiso (Grade A?) only. (From Audiophonics.)Has anyone tried the Hifime High-Speed USB Isolator v2 with the non-isolated Cosmos ADC? It's reportedly using the same AD UM4166 as the Topping HS02 isolator, but only supplies up to 500 mA of current. (And it's cheaper.)
No thanks.Has anybody tried the cosmos ADC with the APX flex software? Looks like it should work...
APx500 Flex Audio Analyzer
www.ap.com
