E1DA Cosmos ADC
Ok when it appears on your AliExpress page, can you ask Sunny to include optional cable purchase also
Giving up soon. Did not think I needed my "esoteric thick cables" but one shot to solder short RCA->XLR (Supra PPSL>Supra EFF-I->Neutrik). Did not work either - identical to my bought RCA->XLR. Using one channel only gives a 50 Hz peak as well, all other peaks the same...
View attachment 297206View attachment 297207View attachment 297208
Started a separate thread about this, since it seems to be a Mac mini-D10s issue.
By the way. Balanced input of preamps have CMRR specification. What is the CMRR of the APU? I can't find it in the spec sheet.
There is THAT1510 as LNA with 120db@60db gain(90db@34db gain) at 60Hz. Cosmos APU notch uses .25% resistors so CMRR 46db is the worst case, average I guess about 65db@1kHz.
Cosmos ADCiso and Scaler panelized ;) IMO it is simply beautiful!
Are you talking about the relay which soldered not straight?
I think it is my mistake, the relay's footprint has too wide pads, so the heavy relay floats during reflow.
It was just a joke,keep up the good work!
Cosmos ADCiso Grade 0, MONO mode reaches THD+N@1kHz -125db. I.e. peak of APx555b THD+N performance level. The sine source of proto of Cosmos DAC, Cosmos Scaler as a buffer with 0db gain, 10Vrms balanced output. Cosmos ADCiso Grade 0 was a random one, just first from the batch, not the best of Grade 0 at all.
Two questions here. Does the TRS input of the E1DA work in mono mode as the two VLR imputs? Secondly will the Scaler be sold through Audiophonics? Cables?
Ok, we are talking about Cosmos ADC, and TRRS AUX input. VRL means XLR? AUX input has a pinout printed at the front panel, the GND you can take from the XLR connector.
Ok, I can see pinouts and have made cables. My simple question is whether the mono and stereo mode (set by master slider i MIDi panel for mac) works identical for the 43Vrms input as with the the two XLR-inputs.
Second question is if the Scaler will be sold by Audiophonics?
sure, AUX tied to the XLRs thru the additional resistor, that's it.
And the second question? Scaler + cables sold through Aliexpress or Audiophonics?
