napfkuchen
Front left/right will be replaced and (ideally) be wall mounted in the same position.
I think how close speakers are to each other is less important to how much early reflections you get. Use absorption panels, if possible.This year I would like to acoustically upgrade my living room setup and replace the front speakers with the 8c and BAACH plugin. However, it's not entirely clear to me if this makes sense in my space...
1. My TV is a 65" model and will perhaps be replaced by an 85" at some point (as soon as there are OLED TVs in this size and you don't have to sell your soul for it). This means that the minimum distance between the speakers is just over 2m (6.6 ft). Does BAACH then even make sense? BAACH Labs' placement graphic suggests that the speakers should be placed closer together:
current setup:
The living room is open to the right and about 7m long; the hallway and kitchen (without doors) are adjacent. So acoustic symmetry won't be achieved.
2. In addition to direct streaming, I would also like to use the speakers as part of the surround setup via Denon 3800X's RCA pre-outs. This should be possible without any problems, or are there any pitfalls?
Stereo actually means 3D.Thanks for your replies.
It sounds stupid, but my thought process was simple: With so much money for a pair of speakers, the (relatively) small additional charge for Ubaach is no longer significant. But it's not a priority.
In the spring some work will be necessary in the apartment, including drilling and dirt/dust. But after that I will follow the advice and listen to the speakers at the distributor near me (only about 30 km away from me) and then hopefully test them at home. I have no idea what stereo in “3D” is supposed to sound like, you can certainly only find out for yourself. Since my experience of 3D sound via Dolby Atmos / Auro3D was rather limited, I don't think it's a huge leap.
Maybe I expressed myself incorrectly... Real 3D would - for me - also include the sound from above and behind with specific channel information. Just like you know from various Blu-Ray discs or Apple Music. To me it usually this sounds very artificial or at best interesting but no better than traditional stereo.Stereo actually means 3D.
