Svart accuses me of lying around 122, I hope you are going to apologise by the way Svart!
Please glance at the post from Christoph Anat of Genelec posted on the Genelec forum.
I am sorry to hear about the damage O , I think D&D may have to look again at the speakers packaging, we have had relatively more courier damage with the 8Cs purely I suspect because they are heavy and large.
Should I apologise for pointing out that you misrepresent information on Genelec repeatedly? To sum up:
1) You claim 8260 roll off at 40-45 Hz. The official specs show response below 30 Hz. I guess they go much deeper than that in-room based on my experience with 8351. You claim that 8260 need subs, as compared to DD8. 8260 is a significantly bigger speaker than DD8, which is reflected in the two speakers’ official low-frequency specs.
2) You insinuate that Genelec didn’t develop its DSP software, which can be understood in two ways: a) that Genelec didn’t R&D its own DSP software or b) that they haven’t developed their DSP software in years. Both insinuations are wrong. The relevant information is easily available on Genelec’s web page.
3) On Gearslutz a representative of Genelec told you to stop misrepresenting the company in a discussion about «The Ones», i.e. its newer range of coaxial three-way speakers (Genelec make the world’s smallest three-way in the world, the 8331). Ilkka of Genelec wrote the following: «Keith,
Your agenda here is clear, but would you still stop spreading false information about Genelec, please? If you would have any actual knowledge, you would know that for example all drivers in The Ones series are designed and manufactured in-house, at the Genelec factory in Iisalmi, Finland, where I work».
4) NEW!!! As pointed out just above, Genelec make the smallest three-way speaker in the world, the 8331a. Any designer knows it’s easier to design and build when space is no constraint. It takes competency to build for the book of records, i.e. a three-way of only 6.7 kg, in a cabinet of 12 litres. Then you go on in a more recent comment with the following statement: «If Genelec made a ground breaking loudspeaker I would stock it.
Keith». Your agenda on Genelec is obvious and I may only speculate why.
In academia, «misrepresenting» is the politically correct word for lying, cfr. professor Flyvbjergs good articles (see previous comment of mine) on the subject of misrepresenting in academia. So I believe the choice of word depends on ASR members view on being politically correct or calling a spade a spade.
I will not apologise for pointing out points 1, 2, 3 and 4.
