manny11701
- Joined
- Jul 18, 2023
- Messages
- 22
- Likes
- 7
- Thread Starter
- #21
I gotta get the box figured out first, but we’ll get thereLet's hope your determination and love of a challenge doesn't falter when you reach the crossover design
Wow, my next steps have already been planned out for me! Phew, that's some time that I can save!Let me guess: you will opt for a two way basreflex with a 7 inch woofer and an 1 inch tweeter, which you can get with a big discount from a local dealer. An already soldered ( some skills are so boring) crossover comes from a supplier abroad. For the cabinet a free of charge exact cut set of panels will be used; for the finish a water based eco friendly paint is prefered. The result will, of course, even surpass your, in advance defined, high demands! And to be mainstream, one or two(!) subs will eventually added.
WinISD will also make recommendations based on that.A parameter called EBP (calculated by dividing FS by Qes) is often used to determine if a speaker is best suited for a sealed or ported enclosure. An EBP close to 100 usually indicates a speaker is best suited for a ported enclosure. An EBP closer to 50 usually indicates a speaker is best suited for a sealed enclosure
Thanks Prana! Appreciate this! I was actually looking up drivers in my price range and plugging them in randomly to see how close to good I'd get, but this should help save me some time!You can DIY whatever you want for whatever reason you want. It's your time, money, effort. Go nuts!
People generally gravitate to towers (or 'monkey coffin' bookshelves, vice the more compact ones in fashion) expecting reference volume bass extension without subs. To get that extension, you're going to need big LF drivers, many LF drivers, ports, or a combination of those.
Keep in mind that ported vs sealed is part of selecting your woofer (or built-in subwoofer) because some drivers will work better sealed vs ported (where 'better' in this case usually means "picking wrong requires an unrealistically enormous box"). Randomly googling reveals:
Everybody uses calculators now. WINISD, AJ vented etc.Have you guys come across any literature that a layman could understand for sizing ports?
The kit speakers I built have an adjustable port and I'm wondering what effect changing it would have.
It's very simple, actually -- it's arithmetic, not maths!Have you guys come across any literature that a layman could understand for sizing ports?
The physics of a box (container) with a hole in it can be found under the moniker of a Helmholtz resonator.
If you're curious, seek out one of Ray Alden's (old) books. I find his treatment of loudspeaker design basics to be accurate and easily digestible.
See if you can find a copy of his book Speaker Building 201.
That said, go with @fpitas's advice & use a calculator.
I see what you mean, the SPL looks a lot better with a Q =0.7. Thanks for the tip, it's been a big help!Yes, double volume for two drivers. I like to tune sealed woofers for no hump, about a Q = 0.7. Some people like the hump, but if you're using a sub I doubt you want it.
There is a large number of things to get right and WinISD doesn't simulate even half of them. I'd prefer a better app, like VituixCAD. Anyway, if you're new to DIY, I'd suggest to try an existing DIY design or a complete kit. These are easy to find.I’ve loved hifi audio and have only recently been intrigued with building my own speakers.
I’m currently designing a pair with a TMM orientation, but one thing that I’ve noticed is that almost all tower speakers in the retail market have a port. Is this necessary to design a good tower speaker?
I’m still playing around with winISD, but another thing I noticed is the ports tend to be quite large on retail towers, but I the program if you use a larger port, it typically also has to be longer, so does anyone know they they’re circumventing this? (I’m assuming the internals are likely a transmission style box.
Cabinet material cost is the lowest in speaker parts. Maybe the screws or wiring is lower, but no body says "the wiring inside tall speakers is so expensive that you shouldn't build tall speakers". It does take time and skill though, if using paid carpenter/service.The port provides better low frequency performance in a given size cabinet. Since the cabinet is very expensive to make an overwhelming number of speaker manufacturers use ported enclosures.
So in-regard to the tower, I've decided to go the sealed route. I'll be using 2 Dayton Audio DA175-8 7" Aluminum Cone Woofers paired with Dayton Audio ND25FA-4 1" Soft Dome Neodymium Tweeter.There is a large number of things to get right and WinISD doesn't simulate even half of them. I'd prefer a better app, like VituixCAD. Anyway, if you're new to DIY, I'd suggest to try an existing DIY design or a complete kit. These are easy to find.
Tuning frequency of a port is the ratio between cross section area and length of the tube. If you enlarge diameter, you need to lengthen the tube to retain the same tuning frequency. Too small diameter will cause higher air speed in the port and lead to unwanted port noises. Your simulator should warn you about this at the SPL you are aiming to. Air volume of the port eats away internal volume of the box, so add that to your calculations.
