How? They have to decide on a form of roll off and a filter length and accordingly on a time frequency behaviorBecause DAC filters are designed to be audibly transparent. They don't alter the song in a way that matters.
If you find DAC filters too restrictive, software upsampling can get quite close to an ideal filter. The DAC is then operating its filter at a higher sample rate, where it has little effect in the passband of the signal.How? They have to decide on a form of roll off and a filter length and accordingly on a time frequency behavior
Our hearing just isn't "that good"How? They have to decide on a form of roll off and a filter length and accordingly on a time frequency behavior
Almost all DACs upsample internally to reduce the effort of the analog reconstruction filter. No need to do this beforehand.If you find DAC filters too restrictive, software upsampling can get quite close to an ideal filter. The DAC is then operating its filter at a higher sample rate, where it has little effect in the passband of the signal.
As an extreme example, a 1 million tap software OS filter can be much closer to the ideal filter than any DACs OS filter. Whether that is significant is another question.Almost all DACs upsample internally to reduce the effort of the analog reconstruction filter. No need to do this beforehand.
Significant would be the delay of such an FIR filter, more than 22 s at 44.1 kHz samplerate ...As an extreme example, a 1 million tap software OS filter can be much closer to the ideal filter than any DACs OS filter. Whether that is significant is another question.
Half that since it is symmetrical: (1M/2)/fs. Also you would not sample to 44.1 kHz but to something higher. For 705.6 kHz, i.e. 16x44.1 kHz delay is only 500000/705600 = 0.7086 s.Significant would be the delay of such an FIR filter, more than 22 s at 44.1 kHz samplerate ...
The same way it is possible to appreciate a painting without the benefit of UV light.How is it possible to judge songs objectively if the native band-limiting characteristics of a song are ultimately overwritten by the DAC filter?
