Parametric EQ with 40 and more filters for TIDAL on Android, Windows, Linux, hardware?
And in order to be able to use a sufficiently powerful PEQ (via EAPO), it is necessary to prohibit TIDAL from controlling the DAC frequency - and this makes it very difficult to use convolution filters!!! Each time the frequency of the material being played changes, it is necessary to manually change the DAC frequency and reboot the EAPO! That is, at least mixes cannot be played using convolution filters.
I don't know what gave you that idea.
It is perfectly fine to set Tidal to Shared mode, load a convolution filter into EQApo, and leave your DAC at one sample rate, regardless of the sample rate of your tracks.
For example, the article that I read on your advice (about how to cancel system APOs) - it also tells about how Windows adds 40 dB of noise when resampling. If the distortions from the mismatch of the filter to the reproduced material are insignificant (how and where can I find out what they are?!), then what frequency do you recommend setting the DAC to? And: 16 or 24 bit?
It does not.
You can use Audacity Wasapi Loopback recording to record all post-Apo system audio, then compare between various configs.
The results can be analyzed using REW or Pkane Deltawave.
Feel free to do your own tests using the above mentioned method.
For my headphones, I keep it really simple with a Loki+ mini analogue tone control between my DAC and my amp.
The four bands have clever Q width control as the knobs are adjusted, allowing me to quickly tune the tone to my liking an the fly (i.e. at the track level if needed).
This works better for me than messing around with electronic/software presets suggested by folks with totally different hearing to mine.
Sometimes an intuitive hardware stereo 5 band parametric EQ is the best path for effectiveness and ease of use. I use a pair of vintage Technics SH-9010s: https://www.kenrockwell.com/audio/technics/sh-9010.htm
Almost never the best path. The problem with such a device is you can't change the centre frequency of each band. And with only 5 bands, they are quite widely spaced. Even with more bands they don't work - if the device you are EQing has. a peak or dip between the defined bands, there is nothing you can do about it.
antcollinet - perhaps you are not familiar with the Technics SH-9010 so let me provide an illustration. Although on first glance its sliders may make it look deceivingly like a graphic EQ the SH-9010 is a fully parametric equalizer with adjustable center frequency and adjustable Q for each band. Orban, Phase Linear and perhaps a few other manufactures also put out parametric EQs with a similar layout. I find this layout more immediate visually than a parametric with only knobs, although I cherish my knob based parametric EQs as well. The other reason I mention the SH-9010 is because it is a true bargain on the used market - especially give its versatility and quality, as the review link I provided in my last post here clearly substantiates.
antcollinet - perhaps you are not familiar with the Technics SH-9010 so let me provide an illustration. Although on first glance its sliders may make it look deceivingly like a graphic EQ the SH-9010 is a fully parametric equalizer with adjustable center frequency and adjustable Q for each band. Orban, Phase Linear and perhaps a few other manufactures also put out parametric EQs with a similar layout. I find this layout more immediate visually than a parametric with only knobs, although I cherish my knob based parametric EQs as well. The other reason I mention the SH-9010 is because it is a true bargain on the used market - especially give its versatility and quality, as the review link I provided in my last post here clearly substantiates. View attachment 469249
You are right - I missed that the dials were dual for frequency and Q - I only saw the (what looks like) fixed frequencies above each slider.
