I voted it poor because it's marketed as an audio device and there is no use case for this in a home audio environment.
No,not a word about audio:I voted it poor because it's marketed as an audio device and there is no use case for this in a home audio environment.
The DJM Electronics ACTIV™ brand EMI Filters are the most advanced and effective EMI filter design available on the market. Utilizing proprietary Digital Signal Processing (DSP) techniques, ACTIV EMI Filters faithfully reproduce digital signals without unwanted or extraneous interference. Military grade passive filtering technology ensures that digital input and output signals traverse the filter in complete and absolute isolation from each other and the outside world. Signal lines are balanced perfectly throughout the multilayered cards to avoid tainting the fast rise times required by digital square wave signals. The result is a pristine digital output far surpassing the filtering capabilities of any other EMI filters.
Every ACTIV™ EMI Filter is constructed with the highest grade electrical components, starting with a super accurate, ultra stable high speed crystal clock which drives the specially developed DSP circuitry and communication chipset. To protect against unanticipated voltage and/or current surges, ACTIV™ Filters incorporate ESD and transient voltage suppressors, inrush current limiters, and gas discharge tubes. ACTIV™ EMI Filters are mounted in a rugged protective housing machined from solid aluminum stock. The housing not only provides physical protection to the filter components, but is also an integral contributor to the filter's effectiveness. The unique structure of the housing effectively disrupts undesirable emissions from propagating through the filter while simultaneously providing low impedance pathways for interference to be directed out of the filter. Between the housing and protection circuitry, ACTIV™ EMI Filters are suitable for nearly any environment ranging from climate-controlled residential use to harsh and unforgiving military applications
Features:
- Proprietary DSP technology provides unmatched EMI filtering
- Military grade passive filtering techniques maintain clean and sharp signals
- Highest grade electrical components deliver long service life
- Rugged protective housing offers reliability in any environment
The word "Audio" on it is at least one word about audioNo,not a word about audio:
(from company's description)
Yep,I stand corrected as this one looks specialized about itThe word "Audio" on it is at least one word about audio![]()
The ACTIV AUDIO™ electromagnetic interference (EMI) Filter is the most advanced and effective EMI filter for streaming audio available on the market. Utilizing proprietary Digital Signal Processing (DSP) techniques, the ACTIV AUDIO™ filter faithfully reproduces streaming audio packets without unwanted or extraneous interference. The filter rejects unwanted signals from 50Hz and below all the way up to 40GHz at better than 100dB -- that's a noise reduction of 99.99999999%! Military grade passive filtering technology further ensures that digital music packets traverse the filter in complete and absolute isolation from each other and the outside world. Signal lines are balanced perfectly throughout the multilayered cards to avoid disturbing the fast rise times required by digital square wave signals. The result is a pristine digital output far surpassing the filtering capabilities of any other EMI filters.
Each ACTIV AUDIO™ Filter is constructed with the highest grade electrical components, starting with a super accurate, ultra stable high speed crystal clock which drives the specially developed DSP circuitry and Ethernet chipset. To protect the sensitive circuitry of the filter, incoming power is also filtered, conditioned and protected against deviations from specified voltage and current levels. The circuit cards are then mounted in a sleek, protective housing machined from solid aluminum stock. The housing not only provides physical protection to the filter components, but is also an integral contributor to the filter?s effectiveness. The unique structure of the housing effectively disrupts undesirable emissions from propagating through the filter while simultaneously providing low impedance pathways for interference to be directed out of the filter.
App level? I don't know of any app level error checking that operates over TCP/HTTP in a LAN. They rely on TCP for that.
There are UDP level applications that perform their own checking (e.g. NFS) but that is not what is used in home audio streaming.
For audio, my tests on high performance streamers shows that the product is not needed. However if you are experience data errors on Ethernet due to special situation you might have, the DJM Electronic's ACTIV Audio Ethernet EMI filter may help deal with that.
But high-end domestic digital is full of this kind of expensive stuff, answering so-called issues that either don't exist these days, or are so insignificant they're way below any remote chance of audibility. I'm thinking of DCS and Chord here as two UK examples. My beef is the silly-high selling price, which may be so to add cachet to it in a largely tech-ignorant market (I'm a suspicious old sod I admit)I think Amir is giving way too much credit to the company.
There's no way such a device, even if needed, should cost what it does. And it isn't needed in any situation you'd have an audio system.
There's no point in bringing in how TCP, UDP or any streaming protocols cope with bit errors etc, because this device is going to have no impact on that in a domestic environment, or probably any other environment either.
The word “audio” in the product name should give you a clueIt's from a company named ACTIV Audio, but does any literature or company info say that the thing is intended as an audio accessory?
I don't know what's funnier, the idea of a critical listen room being next to/on the same network as a CNC machine or the fact that this is actually the case for our studio (right next to my CNC shop/in the same building).I have for example heard of CNC machines causing interference over Ethernet.
The price tag being 100x the expected price of the product is yet another clue..!The word “audio” in the product name should give you a clue![]()
