- Joined
- Dec 6, 2021
- Messages
- 20
- Likes
- 12
Helo All,
I've been reading reviews on this site for a year or so and just now registered. I want to be able to make some decently accurate measurements of speakers I have purchased and some of the speakers I have made. I apologize if this is not the correct or best forum to place this.
I own a Dayton Audio iMM-6 Calibrated Measurement microphone that I use with audio tools on my iPhone. So far the measurements of been like this, a manual process.
Put my iPhone on a stand about 1m from the speaker.
Use "level" to send a test tone at 1000hz, adjust volume until it reaches the expected SPL of the speaker at 1m (usually 88-91db)
Manually test various levels and write down the results (XLS). 20hz, 25hz, etc. Many manual data points.
Using XLS create a decent little graph of my results.
So this is far too tedious and time consuming, plus it's limited to SPL based on a cheap calibrated microphone with output from an iPhone.
Dayton audio makes USB calibrated mics and I have seen other things on the net.
To cut through the BS, what is the best lower cost setup I could use at home to measure speakers? I definitely need software and hardware both. I can spend a few hundred dollars, but cheaper is better. Cheaper leaves me with more money to buy and build more speakers. Thoughts? Thanks guys, love the site.
Nurmdog
Nurmdog
