DIY Speaker measurement
nurmdog
Helo All,
I've been reading reviews on this site for a year or so and just now registered. I want to be able to make some decently accurate measurements of speakers I have purchased and some of the speakers I have made. I apologize if this is not the correct or best forum to place this.
I own a Dayton Audio iMM-6 Calibrated Measurement microphone that I use with audio tools on my iPhone. So far the measurements of been like this, a manual process.
Put my iPhone on a stand about 1m from the speaker.
Use "level" to send a test tone at 1000hz, adjust volume until it reaches the expected SPL of the speaker at 1m (usually 88-91db)
Manually test various levels and write down the results (XLS). 20hz, 25hz, etc. Many manual data points.
Using XLS create a decent little graph of my results.
So this is far too tedious and time consuming, plus it's limited to SPL based on a cheap calibrated microphone with output from an iPhone.
Dayton audio makes USB calibrated mics and I have seen other things on the net.
To cut through the BS, what is the best lower cost setup I could use at home to measure speakers? I definitely need software and hardware both. I can spend a few hundred dollars, but cheaper is better. Cheaper leaves me with more money to buy and build more speakers. Thoughts? Thanks guys, love the site.
Nurmdog
sweetchaos
The Curator
BC, Canada
Plus a calibrated Umik-1 and you’re set.
nurmdog
nurmdog
Thanks! I have read about REW some and wasn't quite sure how good it is. I will give it a try!
Jdunk54nl
Arizona
I’d suggest a focusrite 2i2 or motu m2 and a emm-6 or similar xlr microphone.
You can reach the limits of a usb microphone, you can’t really reach limits from a xlr mic and interface. The xlr mic and mic interface allows for most software analysis too with loopback possibilities for real time impulse response and phase measurements.
617
Somerville, MA
For measurements a umik or umm-6 will work well. Most hobbyists use REW, there are good tutorials for it.
Learn about gating if you want to see quasi anechoic measurements of your setup.
nurmdog
nurmdog
So what about output? Is there a DAC/DSP of some sort that can be used to make a more reliable output audio? My MAC probably has decent output, and I definitely own a few DACs I have tried to use with it.
Jdunk54nl
Arizona
If you buy one of the interfaces I listed above (focusrite or motu) they have output too. If doing on AVR, you will need an hdmi adapter most likely anyway.
nurmdog
nurmdog
Thanks, but I was confused about the mic you suggested. Isn't the emm-6 a USB mic? With those boxes wouldn't it be better to use an XLR mic?
Jdunk54nl
Arizona
The emm-6 is a xlr microphone and the umm-6 is a usb microphone.
emm-6
umm-6
Jdunk54nl
Arizona
I have a couple umm-6's, an omnimic, and a couple emm-6's
If I am just checking something quick, I will pull out the usb microphone. But any critical measurements it is either the omnimic with the included omnimic software or emm-6(s) with Smaart or open sound meter and REW.
I am looking at an Earthworks paired set, but those get pricey and for what I do (mostly just hobby stuff), it doesn't seem critical for me to spend that money compared to the emm-6's
617
Somerville, MA
A usb mic should be able to act as an SPL reference, but a typical XLR mic cannot be used as an SPL reference, unless you know the mv/pa sensitivity of the mic and the exact amount of gain applied by the preamp/ADC.
I personally use an SPL meter and an XLR mic.
Colonel7
Maryland, USA
I'm going by things I wished I had from the start. If you have the budget don't cheap out bc a good measuring rig saves days of time, tedium and troubleshooting. A 2x2 interface is excellent advice. I would add DATS v3, an XLR mic and a scale that goes to tenths of a gram to measure T/S parameters. A decent extendable mic stand so that you can do gated measurements of various size speakers and a cheap but good amp of about 50 watts. Oh, and a bakers lazy susan for off axis measurements.
For software Vituixcad does just about everything but has a steep learning curve. I think not only REW but ARTA is worth learning and trying out depending on what you're measuring.
nurmdog
nurmdog
Thank you all, this great stuff . I’ll do some more research and see costs. I might start with USB mic and free software and consider adding a 2x2 and XLRs. My emotiva amp has an XLR input , so worth considering .
nurmdog
nurmdog
emm-6
umm-6
Thank you for clarifying
bigjacko
If the usb mic can solve the timing issue, what will be the advantage to xlr mic compare to usb mic? JohnPM mentioned that using usb mic with a sound timing reference can get the accuracy to a few micro second, which is good enough for anything you will ever need.
Jdunk54nl
Arizona
A huge advantage to an XLR microphone is real time measurements via loopback. No need to measure, adjust, check to make sure that actually adjusted properly, etc. Constantly updating with real time phase, impulse, magnitude, etc.
Also, if you have ever tried to use REW and getting good timing information, it is not easy via a usb microphone.
Reactions: 617
bigjacko
Thanks for reply, but as mentioned you don't need loop back to have timing reference. By having another speaker making a sound as timing reference is accurate enough.
Reactions: 617
Jdunk54nl
Arizona
Have you used REW to get good timing information to where your phase and impulse graph is accurate?
I have, and while you can get it accurate, it is a real PITA when using an acoustical reference. You also don’t get any coherence information, which is pretty amazing to have as well.
Like I’ve said, with a loopback, a lot of the issues are solved. Also the additional software that can take advantage of this loopback makes everything a lot easier. Open sound meter is free and gives you a taste of the software capabilities. Or watch some videos on YouTube about Smaart or even JL Audio and their new max tune system which utilizes smaart.
If you have used both styles of microphones, you would understand this and the ease of use the loopback brings to the table.
This I also a $200 investment for a xlr mic and interface compared to an $80 investment. Not a huge jump in price for a first time purchase, especially compared to what we spend on this hobby.
But at this point we are going in circles. If you haven’t used both, I encourage you to try it out by buying an interface and xlr mic and download open sound meter You will then understand what I mean.
Jdunk54nl
Arizona
I also did make this post about how you "can" use a usb microphone with open sound meter to get a taste. You run into clock drift issues, but you can at least see what it is like to see this stuff in real time:
nurmdog
nurmdog
Thanks guys, parts express had the umm-6 on sale for $70 and I purchased some tweeters I wanted, and threw in a $10 off coupon, so it was considerably cheaper than the mini dsp. Going to give this a go with the USB mic, I'm excited to see some results.
