It’s interesting that most people in this little area of the internet have…..well not quite a hate on but definitely a disdain for discrete OP Amps. I had no experience nor expectations until I purchased the same DAC my neighbour had, the AUNE X8 Magic DAC. I liked the size and decided I’d try it out to see how an inexpensive DAC sounded. I have several other DAC’s, one a Musician Pegasus R2R solid state and the other the Havana Balanced NOS DAC. I set up AUNE in my system and listened over several weeks. It wasn’t anything special, it was a DAC and it did it’s job. I’m not going to go into specifics as to how much better or poorer it sounded against my other DAC’s, that’s not relevant here.
I had heard a number of reviews where you can swap out the OP amp to the Sparkos SS3602. I ended up emailing Sparkos and the SS3602 was purchased. I replaced the default OP amp with the SS3602 and waited a couple weeks. I’m not a big believer in “burn in” but wanted to get a feel for how it sounded. I did notice after I replaced the OP amp the imaging was way more precise and instruments sounded more real. “I’ll stop the fluttering now!) okay. I don’t trust myself…when it comes to putting in new components..literally. There’s a huge “I just paid and put this gizmo in so it better do something in your mind”. Hey! My neighbour has the same DAC. I called him and we decided we’d do the following on the weekend : set up both DAC’s side by side, made sure they were covered up by a blanket, keep every other component in the chain the same. My Daughter will be switching them back and forth. One has the Sparkos the other has the regular OP amp.
We listened for over a half an hour but the difference was not subtle, it was obvious. Vocals sounded more lifelike, The music had more life to it. The imaging a person experienced opened up. It was the Sparkos. There a lot of descriptions I can use but I’ll boil it down; the Sparkos dramatically improved the sound. It was not just “different”, it was “better”. We listened again repeatedly switching for over another half a hour. Remember all we were doing was unplugging the digital out from my AUDIOLAB 6000 CDT. Then we decided to do another test. We switched the Sparkos into his identical DAC and tried the test again. Again, the results were obvious. One of my Daughters twenty year old friends had dropped by at one point and sat in on it and she listened and picked the Sparkos out as well.
Now this is by no means a “technical measurement”. One could argue many things about this amateur test. However just consider this, our ears have been used for literally many many thousands of years as hunter gatherers. Evolution has refined them to point out objects in your field of view and behind you as well.
Yes, we can measure the discreet Op amps like the Sparkos and I won’t argue that point. However I would encourage any of you to at least consider replacing a solid state OP amp with a discreet OP amp. Sparkos isn’t the only one. I prefer his because he’s a decent young guy who’s started his family business and had their first child. I don’t know him personally but have corresponded with him. I don’t think I’d get that kind of response and help from Texas Instruments! Again, I’m only saying what I experienced with his Sparkos SS3602, there are others. What I will say is from what I've experienced it was well worth the money. To recap: I’m not one for gimmicks, I’m well aware of all the “hype” and blatant misinformation out in the Audio world. This was simply an attempt to let you folks know what I and my Neighbour have experienced.
Happy Holidays to all!
