Dirac Live Exclamation Mark issue
Can you be more specific? I have Dirac and one of those Harman Luxury receivers and it would be good to know what issues people are having.
It is impossible to summerise all my post in Avsforum since 2 years. Suffice to say if you paid for DLBC licence (not basic DL or DLBM) stay with Dirac v3.4.4 and none update above this works properly. I repeat I speak of DLBC not DL or DLBM.
Go there and pages ahaead and follow our journey
And
I still can’t get consistent precise measurements with my minidsp HTx. Tried again last week. This time in a near field setup (same room, same system).
When you say consistent precise measurements are you talking about frequency or timing? What microphone? While the UMIK-1 works well for frequency measurements it is known to have issues with timing measurements. https://www.avnirvana.com/threads/acoustic-phase-measurements.13300/#post-99941
"Imprecise measurement, can be used but not for phase correction". I use a umik-2 and a million tests for Dirac / MiniDSP. Given up. I just post this every now and then to remind people that it's not a slam dunk result.
As of now what is the best bet to beat this?
1 downgrade dirac version
2 buy umik 2
3 buy another mic
2 buy umik 2
3 buy another mic
I don't know if it is relevant for miniDSP but you must set Win10 or 11 inyour laptop to Dirac to take exclusive control of the mic settings in win10 or win11
How is that done?
From Dirac v3.10.3
To improve the quality of measurements with microphones connected to Windows PCs, WASAPI Exclusive Mode will be activated by default in some cases.
To control whether Exclusive Mode is used or not in your case, and thereby override the default behavior, please follow these steps:
Click the Windows button, type “env”, and hit Enter
Click the "Environment Variables..." button
Click the "New..." button under "User variables for <user>" (or select DAUDIO_WASAPI_NON_EXCLUSIVE and click “Edit…” if it already exists)
Enter Variable name: DAUDIO_WASAPI_NON_EXCLUSIVE
Variable value "OFF" = Exclusive Mode enabled
Variable value "ON" = Exclusive Mode disabled (the old behavior)
Click “OK”
Restart the Dirac Live application
Verify that it is possible to complete a calibration.
2 buy umik 2
3 buy another mic
FWIW, the current version of DLBC and a UMIK-1 work well for me (never throw up measurement errors) and produce good results.
I'm using the stand-alone processor, not an AVR, if that matters.
All I get are "imprecise measurements".
Try a different USB input on the PC. It is also possible to connect the mic directly to the M33.
Are you using the NAD mic?
Someone tried Dirac Live Beta 3.13.4 // 2025-04-30 to verify the behavior of BC?
Changes listed are relative to the latest public stable release.
Features
- Renamed Volume Calibration page to Measurement Levels and updated guiding text.
- Renamed Select Arrangement page to Select Sweet Spot and updated guiding text.
Bug fixes
- Fixed an issue which blocked filter export for larger systems, for example on NAD multichannel devices.
Known issues
- ART filters for systems configured for 2.0.0 channels cannot be exported with this release.
- Progress tracker can sometimes jump backwards.
I have never had the exclamation mark issue since v3.10 if I remember correctly
(using a PC and UMIK-2)
No need. Last emails about Arcam/JBL 2 years old DLBC bugs and Denon crossover DLBM/DLBC bugs say that Dirac still searching for a solution.
Don't pay for DLBC licence it is not worth it.
Features
Bug fixes
Known issues
In fact there is the official 3.13.2 release which brings many more changes:
Dirac Live 3.13.2 // 2025-02-28
Features
ART support range sliders now take precedence over the detected range of a speaker.
In cases where there is no subwoofer used as support speaker, ART filter designs could sometimes result in undesirable magnitude boosts at frequencies between the speaker’s detected low cut-off and the user’s selected low end of the ART support range.
The workaround has been to manually adjust the advanced target curve to not “ask for” more bass than the available supporting speakers can provide.
The updated functionality will instead use the selected low end of the ART support range to limit, or contain, the magnitude boost applied by the ART filter design. Therefore, it will not longer be necessary to adjust the advanced target curve to achieve a “reasonable” ART filter design.
The LFE group in ART now uses a non-subwoofer speaker to define its time target.
ART utilizes the measured wavefront propagation of the main speaker in each microphone position to define the time target response for that channel.
For the LFE channel, ART utilized the first subwoofer in the LFE group as main speaker for the LFE channel. However, this has two drawbacks:
The main peak in a subwoofer’s impulse response can sometimes be difficult to detect. In cases where the detection has failed in one or more microphone positions, the resulting target may not represent a desired wavefront propagation.
When multiple subwoofers are used, then ART may “unfairly” assign too much power to the first subwoofer, due to its measured capability to contribute more effectively to attaining the target (which was defined by its measured response) than the other subwoofers.
The updated functionality will use a full-range speaker to define the time target for the LFE channel.
If there is a Center speaker, ART will try to identify it and use it as target.
If a Center speaker cannot be certainly identified, then ART will use either the Front Left or the Front Right speaker as target.
The advanced ART settings for the LFE channel group has a drop-down menu to let the user manually override the automatic selection.
When Dirac is handling bass management (BM, BC, ART), the LFE channel will always have a low-pass filter applied at 120 Hz. This is to comply with LFE channel handling requirements and be consistent with the Dirac Live Bass Control (DLBC) behaviour.
ART now supports the case where some speakers are excluded from supporting other speakers. However, they may still receive support from other speakers when they are enabled.
Reduced the time it takes to export a filter to Onkyo/Integra/Pioneer devices.
Bug fixes
Fixing a few issues related to measurements taken while an AVR was on an older firmware and using them for filter design and filter export to the same AVR with an upgraded firmware:
Dirac Live could crash when clicking the Bass Management filter design option.
Bass Control filter design could fail with a message “Malformed request”.
Filter export could fail with an error message “Failed filter export”.
Fixed an issue where Dirac Live could crash when calculating a Bass Control filter with a narrowband subwoofer.
Fixed an issue where Dirac Live could crash at the end of ART preprocessing for a 2.1 system.
Fixed an issue where Dirac Live could silently fail to load an older ART project, showing no measurements in the filter design page.
Fixed an issue where loading a stored Dirac Live filter design snapshot would put the filter design in a wrong state - as if it had a completed filter design, which it didn’t. An attempt to export that filter design to the device would fail.
Fixed an issue where an offer to upgrade a license to ART wasn’t shown when connected to a device supporting ART.
Adjusted the LFE low-pass filter cut-off frequency in Bass Control to be -3dB at 120Hz. It was previously erroneously set to -6dB at 120Hz.
Fixed an issue where the Bass Control subwoofer impulse response plots were not properly scaled, almost appearing as having zero amplitude (flat).
Fixed an issue in the Filter Export page where the text input box for the filter name would sometimes lose focus while typing.
Missing/wrong signing for the previous beta releases has been fixed.
Other minor bug fixes and under-the-hood stabilizations.
Known Issues
The animations in the Dirac Live UI during measurements have been temporarily disabled. This is because we have found that the animations cause high CPU load on some computers, both PCs and Macs, resulting in audio buffer loss in the measurements. The measurement progress can be followed in the progress percentage, which is still displayed.
Processing progress percentage can in some situations jump backwards. This doesn’t indicate that there is a problem with the processing it
self. It is only the calculation of the progress that needs fixing.
In any case, for over a year I have been in the same situation of GD absurdly increased with BC, and audibly inconsistent filters between generations, especially in terms of spatiality.
As a customer, being in this situation and not seeing / knowing if and when this will be fixed is really annoying, especially for having spent a lot of money on a SW which on paper is the leading edge for acoustic correction.
Not to mention the annoyance of trying other room correction software, less famous, less sophisticated, developed by one person, and even free at times, and not miss the lack of DIRAC at all....
Wich DSP solutions did you use besides Dirac with adequate/comparable results?
or MiniDsp 2x4HD + MSO+ REW
Dedicated laptop (small Lenovo Thinkpad fast I5 Intel) with 2TB SSD runs the free MathAudio Room EQ (DSP) and Foobar2000, starting up in 30 seconds. Controlled remotely via MonkeyMote on mobile. Once powered on, the system runs fully autonomously—handling connectivity to Topping DAC, amp, speakers, and server access—via housewide Wi-Fi and Bluetooth. For me this is for now the most comfortable/ideal solution making use of quality DSP an housewide high quality music acces/connectivity using minimal technical knowledge bit perfect not breaking the bank ;)
I have a new set up which is pretty straight forward and was going to give DLBC another try. Any advice on whether to try the newest beta version or the latest stable version or an old version greatly appreciated. Thanks
