theREALdotnet
- Joined
- Mar 11, 2022
- Messages
- 1,723
- Likes
- 3,056
I’m mainly using Audirvana for music playback, but the Music app or Safari work just as well with Dirac Virtual Audio Device as playback device.
DLBC integrates subwoofers with the main speakers. With Dirac only, you have to do the integration some other way first, and then Dirac corrects the overall sound.What's the difference between Dirac without DLBC and having it?
Dirac Live Bass ControlWhat's the difference between Dirac without DLBC and having it?
Not the case.
I think that the miniDSP FLEX cannot support Dirac Live Bass Control as four independent channels are required while the FLEX has two input channels only,@Flak Many of us utilize Dirac Live through components such as miniDSP FLEX. The room measurements, processing and filter adjustments are made on a PC, then transferred to the miniDSP component for use. Will DLBC available for these miniDSP users? Will there be an additional cost or will this be a free upgrade?
Thanks!
www.audiosciencereview.com
The NAD M66 also has two input channels only and supports Bass Control.I think that the miniDSP FLEX cannot support Dirac Live Bass Control as four independent channels are required while the FLEX has two input channels only,
sorry
I very much hope that a miniDSP processor supporting DLBC will be available in the future... currently, for my personal 2.2 system, I'm using this audio card that measured quite well as a DAC:
Motu M4 Audio Interface Review
This is a review of Motu M4 4x4 audio interface (DAC and ADC). It is on kind loan from a member and costs US $220. The enclosure is heavy gauge metal and sturdy: The front inputs are for microphones with higher gain. For my testing I used the Line in (and out) in the back: For testing I...www.audiosciencereview.com
With reference to the NAD M66, my understanding is that the channels for the subwoofer/s are available via NAD BluOSThe NAD M66 also has two input channels only and supports Bass Control.
But I also don’t think the Flex will get BC support. Dirac live+ BC would end up costing more than the Flex itself
sorry
The filters creation happens prevalently in the computer and partly in the cloud (more in the future) while the real time processing of the filters will happen in the computer if the standalone Dirac Processor is used... if not, an external processor is used (i.e the Flex, an AVR, a Dirac enabled speaker, etc.)And Dirac processing happens in the computer?
