- Joined
- Aug 14, 2018
- Messages
- 2,817
- Likes
- 8,288
I know there are lots of discussions about devices like USB to AES converters, but I'm wondering about something slightly more complex:
I have two digital sources, one coaxial and one USB. And I'm looking for the simplest, most economical way of feeding both to active speakers with AES EBU digital inputs.
So I'm looking for two inputs - coax and USB - and one output - AES EBU, but honestly I would settle for a coax output since my cable run from that output to the AES input of the actives is only 6 feet and I've been using an RCA-XLR cable (75 ohm, not even 110 ohm) with zero problems.
I know MiniDSP makes devices that can do this: the SHD does it, and the SHD Studio is even better because it provides that AES output. But these devices are $1200 and $1000, respectively, and they are overkill if one doesn't need DAC functionality (SHD) or streaming and Dirac (SHD and SHD Studio).
There's also the Mutec MC-1.2, but it's long discontinued and the odd one that pops up on eBay seems to go for $500 and up.
There appear to be a decent number of converters available for $250 or less (Gustard U12, Xing F200 and clones, Hosa devices, etc), but they all have only a USB input - they have no additional input and therefore no switching capability.
I've also looked into basic digital switches, but they all appear to be toslink and coax only, so one would have to feed one of the inputs with a USB to toslink or USB to coax adapter, which means you'd have to insert something like a Topping D10 ahead of the switcher, and in my case for that signal path you'd end up with USB to D10 to Toslink to switcher to coax to AES, which just seems stupid (and a recipe for trouble in terms of jitter, signal syncing, or other glitches).
So - aside from $1800 RME DACs that might happen to have the right inputs and outputs on them - is there anything on the market that I've missed or haven't found?
Thanks!
Thanks!
