Cheapest option is probably a used X3700H.What are the least expensive AVRs with XT32?
That makes sense. Bit tough to swallow since i'm on a temp receiver until I can get my long term one. Would be nice to use MultEQ in the interim.
Great idea. I too purchaed MultEQ-X after I thought I was so lucky in getting a x3600h before the pandemic completely upended supply chains.I agree. I purposefully put MultEQ-X on a brand new x3700 that I chose which came with six years warranty. Thought that should get me my money's worth!
Unfortunately, I more recently upgraded my video to a 4k/8k projector and also obtained a PS5. The price of certified refurbs of the x3800h came way down, so HDMI 2.1 became more of a draw, and I sprung for it.
At least I can still use the x3600h in a secondary room. That room is boomy and vaulted, so at least the MultEQ-X is possibly? doing more than was needed in my theater room.
For me the XT did an excellent job, LP 1/48 smoothing, without smoothing is the same. I have the app and I only use filters up to 300hz.
That does look decent, but it could be that your room is playing nice to your speakers. Could you show one that shows Audyssey XT on versus with Audyssey XT "OFF"? Then we can see how much improvement XT managed to achieve. If it is in fact as good as your graph show, XT32 may be able to further smooth it by a couple dB regardless, but that would not likely make any audible change.
XT sure is better than the basic one but it's still not really able to correct anything in your speakers' bass and make very basic broad corrections to your subwoofers, which is extremely subpar compared to XT32 and higher end room EQ systems.Recently, I purchased Denons X1700H, from Denon, with XT. My previous 6 year old Denon had MultEQ. In my audio files, I have always turned off anything to do with Audssesy settings. I can tell you, the XT shines, in my 5.1 system, over the plain MultEQ, in my environment. My HT room is small, 8 X 12 with one person front and center.
