thefsb
- Joined
- Nov 2, 2019
- Messages
- 796
- Likes
- 657
Do you know a suitable stand for these boxes? Or can you suggest how to DIY something simple?
Height 419 mm (16.5")
Width 254 mm (10")
Depth 308 mm (12.1")
Net Weight 8.1 kg (17.87 lbs)
I'd like to lift them up a bit and maybe point them upwards a bit too. Some adjustment would be great but I'll consider also without.
They will go either side of a 32" display panel.
Width 254 mm (10")
