I did turn the volume up (don't assume it wasnt tested on all volume levels). Situation was the same. Yamaha was "loud" but sound impression remained the same: distant treble (though nice imaging), emphasized bass. Went loud with Marantz - got the clarity and balanced bass/mids/highs.If that's the case, all you had to do was to turn the volume up by a few dB and your impression would have changed. I understand you said you wanted to like the Yamaha so you were not biased that way, but you would still be under the influence of other factors unless you did follow a tightly controlled protocol.
The importance of THD at below 1 W is valid but one also has to consider the noise floor in most rooms the actual THD level and spl you are getting under that specific condition. Another issue I have is that people often refer to the tests by that site, but if you look carefully, their results look very different compared to ASR's, Audioholics, and others such as hometheaterhifi.com's. I am really skeptical with their methodology and the test gear they use. Just compare the graphs you posted and the one Amir did on the R-N803 and you'll know what I am talking about.
Just curious, have you tried some of those listening test such as Klippel's and see how you could consistently tell the difference between 0.1% THD or even 1% THD? In this case, even going by that Polish site's graphs, the difference in THD+N between the two at 0.1 W is only 0.2%, and at that level, it could have been mostly noise too depending on again, their test gear and procedures use.
Distortion Listening Test
Ran into this interesting listening test by Klippel with regards to how much distortion you can hear. This is the link: http://www.klippel.de/listeningtest/lt/ Just casually wanting to see the test, I went with the defaults and for some reason, the levels were exceptionally low. I had to set...www.audiosciencereview.com
THD+N doesnt have to be decisive factor (since the difference is really small).As for the Klippel test, with noisy room and headphones, reached -18dB.
Perhaps Yamaha's AB class Sunken transistor aren't great regarding powering impedance speakers like JBL Stage A180.
