Denon DCD-SA1 Review (CD/SACD Player)
The only interest of the SACD was the multichannel, also present on the DVDA, much more practical. Unfortunately both seem to have been abandoned in favor of the BRDA.
I find SA-CD much more practical than DVD-A : in use, SA-CD works like a CD Audio! DVD-A are much more cumbersome to use for my liking (from the limited number of DVD-As I have).
You will need an AVR for multichannel anyway, the native digital stream is copy protected so only the analog output can be processed. We don't have the same definition of the word practical.
Great review, as always.
The AL processing somehow is the audio equivalent of the Volkswagen exhaust manipulation, albeit with less damage.
Remember that besides the filter switching there is also the interpolation algorithm.
Well, I can imagine too, that the original idea was for its intended eventual use to be, after the system was vetted, as an archiving format.
Certainly as a recording or production format, it was rather not fit for purpose. That had to be known very early on. Your/BE's scenario would mean that mean Sony knew from the start that likely they'd have to use PCM somewhere in the production chain of SACDs (DXD or "DSD wide', as it later was known). Rather than that being a consequence of re-orienting DSD to commercial SACDs, as in my scenario.
Indeed, they probably knew from the beginning that editing is DSD would be too complex because of its deviation from 2’s complement representation. I work very close to Merging (geographically speaking) who developed DxD with Philips (which, as you suggest, is PCM), and I always wanted to say hi and thanks to them but I don’t have a good reason to bother them :)
As explained by Black Elk on SHF, Philips, contrary to Sony, did not have a pro-audio division and thus chose to work with Merging by transferring expertise on digital signal processing and let them put on the market the appropriate stuff to support SA-CD production. According to BE, Philips's engineers thought that processing at 16 FS PCM (705.6 ksps in 44.1 ksps based system or 768 ksps in 48 ksps base system) was necessary to keep the time domain performance of DSD signals, but Merging didn't have the technical platform to achieve that sample rate at the time. As a result, Philips and Merging acknowledged to fell back on 8 Fs PCM (352.8 ksps or 384 ksps), which was within the possibility of Merging hardware and software portfolio at the time. Merging decided to name its format system DXD, which angered Sony, which owns the rights to the DSD acronym and felt that Merging was commercially parasitic by taking advantage of the fame of the DSD name. But eventually everyone agreed to allow Merging to use the name DXD.
The following is my understanding from years of researches and reading in the Internet archives.
The Merging system was not put on the market before 2004. Before that, DSD was already editable, within some limitations, thanks to Sony hardware and software.
Sony engineer Ayataka Nishio is credited to have led the development of the first digital signal processor to edit DSD for production purpose. He had presented this chip as early as 1997 in an AES convention in Munich. Based on this chip, Sony had created the Sonoma hardware/software recorder/editor combination to support production. This DAW was not put on the pro audio market at the beginning, but lent to various facilities in the world to help support recording music for SA-CD production. It is still in use today in some studios, as can be seen here: https://www.sonymusicstudio.jp/s/studioen/page/equipment?ima=5651#section5
Sonoma was a mobile recorder/editor running on computer under Windows environment. Here is the back of such a computer, with the connector side of an early Sonoma processing card, which interfaces with outboard A/D and D/A converter:
And here is a view of the Sonoma processing card, with four Sony CXD2926 DSD edit processors, which were dubbed "E-chip":
It can be noted that the DSP chips are labelled "CXD2926AQ". In the Sony Semiconductor naming system, the suffix letters "Q" means "QFP package" (as can be seen) and "A" means "Improved specifications". The visible chips thus belong to a second generation.
According to Nishio's presentation, the CXD2926 is a 4 tracks input/2-channels output chip, hence the 4 chips on the processing board, which can handle up to 8 channels DSD (remember an SA-CD has 8 channels total, 2 stereo, 6 in multichannel). This chip was capable of level control, switching between DSD stream, cross-fade, fade-in/fade out and, under some conditions, equalisation. The level control is absolutely straightforward. The switching part was the most difficult to implement because, as pointed out by NTTY, a DSD stream has no "0" level and hence, signal-dependant DC levels are part of the DSD signal. Dealing with switching requires very thoughtfully designed processing with carefully synchronised fade out/fade in process to avoid abrupt transition between two DSD streams. By the way, such a processing was incorporated in the decoder (of the Sony CXD275x or Philips "Furore" family) of every SA-CD player from the very beginning of the format to avoid "clicks" at the beginning of a track or from track to track.
The little ad-on card at the upper right corner of the Sonoma processing board is another part of the pro-environment created by Sony Oxford, Sony's European pro-audio division: the Super-MAC digital multitrack interface. It was able to transmit up to 24 DSD channels or 6 to 48 channels of PCM Audio from 16 to 24 bits and 44.1 ksps to 384 ksps through Ethernet cable. This interface was later improved to the Hyper-MAC standard. The output RJ45 connector of the interface can be seen at the back of the computer on the first photography.
I wrote that the CXD2926 is capable of equalisation under some conditions. It is there where PCM intervened, but not through a conversion from DSD and back to DSD. The process is much weirder and is described in Ayataka Nishio's patent on the subject (US 5,835,043). A PCM signal path with suitable sample rate is derived from the input DSD stream. This PCM signal path contains only the frequency pass-band of interest (obviously). This PCM signals is equalised as desired, then subtracted from the input PCM stream to get the difference between the two. This difference signal is linearly interpolated up to the DSD sample rate and add to the input DSD stream, which had been appropriately delayed of the time necessary to do the processing on the PCM streams. This addition produces a multi-bit signal at DSD sample rate which is re-modulated back to 1 bit by a following sigma-delta modulator. Weird, but it works that way.
But that was just the beginning.
Soon, Sony Oxford entirely discarded the weird process that have been devised by Nishio for equalisation and designed digital processing on multi-level delta-sigma modulation. For that matter, DSD 1 bit delta-sigma input streams are transformed into multi-level (at 8 bits depth coding) sigma-delta streams at the same 2.8224 MHz sample rate as the input signal in order to interface them with internal digital processing blocks on an entirely new processing board. It is this intermediate interfacing digital format that has been dubbed "DSD-Wide". The rationale behind the technical choice made by Sony Oxford and the overall system description was exposed at an AES convention in Amsterdam in 2001. It is from this presentation that I extracted this rare low-res photos of the new processing board (I hope publishing them is fair use):
Later on, Sony Oxford leveraged this new expertise on signal processing on multi-level delta-sigma modulation by releasing on the pro market D-MAP processors sold to third parties. D-MAP is the acronym of "DSD-Modular Audio Processing". It takes the form of small PCB boards where algorithms developed by Sony Oxford are implemented in FPGAs (Field Programmable Gate Array). Various modules having precise capabilities were put on the market, such as this one dedicated to make compressor/limiter, where we can see a photo of the hardware module (excerpt from a promotional brochure at the time):
Sony Oxford has even developed a technological demonstrator of a fully digital preamplifier on the basis of a D-MAP development board in the hope to attract the interest of the consumer electronics producers (excerpt from a Sony Oxford commercial brochure of the time):
Of course, as we all know, no consumer electronic producer expressed interest to incorporate this technology in their products.
As far as the pro-audio market is concerned, what has been achieved ?
Sonic Solutions released a seemingly rare DAW extension based on a first processing card named DSD.1 with Sony CXD2926 processors and later a more powerful extension named DSD.X with Sony Oxford D-MAPs. To my knowledge, this system is the only DSD-capable DAW that has ever been created to run on Apple's Mcintosh system. It has been used by some in the UK, including the BBC : I was able to find a thread on a UK pro-audio forum, where a person was desperately in search of the system to read the digital file format used by this Sonic Solution DAW and was led towards the BBC. It should be noted that a Sonic Solutions guy named James A. Moorer had previously put forward a presentation about DSD signal editing with Ayataka Nishio at an AES convention in 1998. So, there must have been a relatively old relationship between Sony and Sonic Solutions on that subject. Here is a screenshot of a long gone Website with a view on the hardware parts:
Another client of Sony Oxford for D-MAP modules is Genex, which has released a DSD-capable DAW, but at a later date (2007). It was the "Mix+" hardware/software engine. Here are views of the hardware enclosure and the internal processing card with D-MAP modules whose processors are covered with heat sinks (photos found on an auction website!):
Last, probably the most well known DSD-capable DAW is SADiE 5.0 (from 2003 onward), which used Sony Oxford D-MAP modules:
As for Sonoma, the software system was lately transferred to Gus Skinas's Super Audio Center (Boulder, Colorado, USA), that has kept developing and distributing it for a while till an end date I don't remember. But I have heard from Mr Skinas in an interview he gave that the last Sonoma system he had delivered was for the Daft Punk, to be used during the production of the famous Random Access Memory album. The hardware side of the Sonoma system still made use of D-MAP modules from Sony Oxford. The system has been extended to 32 tracks, as can be seen in this ad blurb of the time:
Of course, all of that is old history, even if numerous of the above mentioned DAWs are still in use in multiple places.
DSD-Wide is often presented as a PCM signal and thus had been nicknamed "PCM-Narrow" by some. But, to the best of my understanding, that is definitely not true for the following fundamental reasons.
PCM is a kind of modulation where the analogue signal of interest (the audio) is sampled at a certain rate and the resulting samples of the signal are converted in digital words which correspond to the respective level of each sample of the signal of interest. It straightforwardly is a direct description of the signal of interest.
Sigma-Delta modulation does not contain samples of the signal of interest (the audio). The system relies on noise-shaping, whose very principle is to take into account the state of the output, in order to shape the noise (the quantification error). What is sampled is not the signal of interest but an error signal which is the product of the processing of both the input and the output of the system. The fact that the modulation contains only two levels (1 single bit) or multiple levels (eventually expressed with multiple bits in a digital system) depending of the design of the modulator does change nothing to the fundamental difference, ie a delta-sigma modulator samples a derivative function of the signal, not the signal itself.
At least that's what I understand about how both systems work. But I also think that once you get out of the cold technical analysis, all the debates around this subject boil down to the debate about the sex of angels.
I forgot! :eek::eek::eek:
Indeed, it increases the bit depth. This is the output from digital:
An this is the output from analog (RCA):
A bit nasty because of noise (some of it from my interface too), but we still see that we are far from a representation of the 3DC levels. So yes, the Alpha filter interpolates through an increased bit depth.
Thanks for reminding me of that!
Flo
Thanks @Scytales for the info, this is very interesting and detailed, amazing.
I've been told that Sony offered some sort of editing in DSD but I did not know it went as far as limiter, delay or equalization. Thank you again for the lecture!
Indeed.
The fact that the folks at Sony and Philips must have seriously thought that DSD was the way forward at one point (on its technical merits, not copying concerns) leaves me utterly baffled. The Lipshitz / Vanderkooy paper was the final nail in its coffin (alongside DACs with multibit modulators) but its poor storage efficiency can't have been a secret. And then SACD still managed to be the most successful (or least unsuccessful) "HD" audio disc format, pushing way more sensible formats like DVD-Audio to the wayside. With such major efforts behind the scenes, it's not a surprise, but you can't help but wonder what would have happened had the same effort gone into a more sensible system.
No, because if you used good ripping software, every bit was extracted perfectly because the computer CD player went over the same place several times to extract everything without error...
Or at least looked up whether the ripped audio checksum matches online databases.
There's the one thing that does not get extracted though, and that's the subcode. This is why we do not have subtracks, and with most rippers you're out on your own when it comes to applying deemphasis to the handful of CDs that need it.
That was some amazing detective work Scytale, thanks. (nice Dune ref there too)
What strikes me is what an enormous effort and ingenious kludging (i.e., everything involved in making DSD somewhat workable in a production environment) was put into something for so little, if any, sonic gain. High rate PCM had already pointed the way towards the future.
Copy protection must meant an awful lot to Sony.
(and even that is history now, for every physical delivery format..they have all been hacked)
Except that the music branch of Sony, managed from New York, as heiress to CBS records, was being lured into publishing SACDs...
Very few were published and they were single layer (without CD layer) due to musicians' rights problems in the United States...
And there was no one at Sony's general management to order the music recordings branch to publish more and especially DSD + CD multilayers...
Same at Philips in the Netherlands: the record publisher Philips did not publish any at all in Europe (a few in Japan: I have some) but at the same time began to copy all its analog tapes in 24/ 96 PCM according to the director of the back catalog, Canadian Tom Deacon.
So the copying problems...
As explained by Black Elk on SHF, Philips, contrary to Sony, did not have a pro-audio division and thus choose to work with Merging by transferring expertise on digital signal processing and let them put on the market the appropriate stuff to support SA-CD production. According to BE, Philips's engineers thought that processing at 16 FS PCM (705.6 ksps in 44.1 ksps based system or 768 ksps in 48 ksps base system) was necessary to keep the time domain performance of DSD signals, but Merging didn't have the technical platform to achieve that sample rate at the time. As a result, Philips and Merging acknowledged to fell back on 8 Fs PCM (352,8 ksps or 384 ksps), which was within the possibility of Merging hardware and software portfolio at the time. Merging decided to name its format system DXD, which angered Sony, which owns the rights to the DSD acronym and felt that Merging was commercially parasitic by taking advantage of the fame of the DSD name. But eventually everyone agreed to allow Merging to use the name DXD.
The following is my understanding. from years of researches and reading in the Internet archives.
The little ad-on card at the upper right corner of the Sonoma processing board is another part of the pro-environment created by Sony Oxford, Sony's European pro-audio division : the Super-MAC digital multitrack interface. It was able to transmit up to 24 DSD channels or 6 to 48 channels of PCM Audio from 16 to 24 bits and 44.1 ksps to 384 ksps through Ethernet cable. This interface was later improved to the Hyper-MAC standard. The output RJ45 connector of the interface can be seen at the back of the computer on the first photography.
I wrote that the CXD2926 is capable of equalisation under some conditions. It is there where PCM intervened, but not through a conversion from DSD and back to DSD. The process is much weirder and is described in Ayataka Nishio's patent on the subject (US 5,835,043). A PCM signal path with suitable sample rate is derived from the input DSD stream. This PCM signal path contains only the frequency pass-band of interest (obviously). This PCM signals is equalised as desired, then subtracted from the input PCM stream to get the difference between the two. This difference signal is linearly interpolated up to the DSD sample rate and add to the input DSD stream, which had been appropriately delayed of the time necessary to do the processing on the PCM streams. This addition produced a multi-bit signal at DSD sample rate which is re-modulated back to 1 bit by a following sigma-delta modulator. Weird, but it works that way.
Later on, Sony Oxford leveraged this new expertise on signal processing on multi-level delta-sigma modulation by releasing on the pro market D-MAP processors sold to third parties. D-MAP is the acronym of "DSD-Modular Audio Processing". It has the form of small PCB boards where algorithms developed by Sony Oxford are implemented in FPGAs (Field Programmable Gate Array). Various modules having precise capabilities were put on the market, such as this one dedicated to make compressor/limiter, where we can see a photo of the hardware module (excerpt from a promotional brochure at the time):
Sony Oxford have even developed a technological demonstrator of a fully digital preamplifier on the basis of a D-MAP development board in the hope to attract the interest of the consumer electronics producers (excerpt from a Sony Oxford commercial brochure of the time):
As far as the pro-audio market is concerned, what have been achieved ?
Sonic Solutions released a seemingly rare DAW extension based on a first processing card named DSD.1 with Sony CXD2926 processors and later a more powerful extension named DSD.X with Sony Oxford D-MAPs. To my knowledge, this system is the only DSD-capable DAW that have ever been created to run on Apple's Mcintosh system. It has been used by some in the UK, including the BBC : I was able to find a thread on a UK pro-audio forum, where a person was desperately in search of the system to read the digital file format used by this Sonic Solution DAW and was lead towards the BBC. It should be noted that a Sonic Solutions guy named James A. Moorer had previously put forward a presentation about DSD signal editing with Ayataka Nishio at an AES convention in 1998. So, there must have been a relatively old relationship between Sony and Sonic Solutions on that subject. Here is a screenshot of a long gone Website with view on the hardware parts:
Last, probably the most well known DSD-capable DAW is SADiE 5.0, which used Sony Oxford D-MAP modules:
As for Sonoma, the software system was lately transferred to Gus Skinas's Super Audio Center (Boulder, Colorado, USA), that has kept developing and distributing it for a time till an end date I don't remember. But I have heard from Mr Skinas in an interview he gave that the last Sonoma system he had delivered was for the Daft Punk, to be used during the production of the famous Random Access Memory album. The hardware side of the Sonoma system still made use of D-MAP modules from Sony Oxford. The system has been extended till 32 tracks, as can be seen in this ad blurb of the time:
DSD-Wide is often presented as a PCM signal and thus had been nicknamed "PCM-Narrow" by some. But, to the best of my understanding, it si definitely not for the following fundamental reason.
PCM is a kind modulation where the analogue signal of interested (the audio) is sampled at a certain rate and the resulting samples of the signal are converted in a digital words which correspond to the respective level of each sample of the signal of interest. It straightforwardly is a direct description of the signal of interest.
Sigma-Delta modulation does not contain samples of the signal of interest (the audio). The system rely on noise-shaping, whose very principle is to take into account the state of the output, in order to shape the noise (the quantification error). What is sampled is not the signal of interest but an error signal which is the product of the processing of both the input and the output of the system. The fact that the modulation contains only two levels (1 single bit) or multiple levels (eventually expressed with multiple bits in a digital system) depending of the design of the modulator does change nothing to the fundamental difference, ie a delta-sigma modulator samples a derivative function of the signal, not the signal itself.
At least that's what I understand about how both system work. But I also think that once you get out of the cold technical analysis, all the debates around this subject boil down to the debate about the sex of angels.
One of the post that justifies the time spent here.
Thanks for this!
So,where this DSD-can't-be-edited myth comes from?
The rarity of the gear?Their price?
Yes, I recall (and have owned examples of) non-hybrid SACDs, and stereo-only SACDs (the Thriller SACD mastering is still for me the sonic gold standard for that album, even with its small batch of 'illegal' sample values -- fortunately not audible) , and then, multichannel + stereo, hybrid, SACDs. For all I know there were also multichannel/stereo nonhybrid SACDs too, to round out the menagerie. (I don't think there were any multichannel-only SACDs...but I could be wrong!)
Which to me seems a much more sensible path.
Well, there is copy protection on DVDAs (and BlueRay) too...which worked...for awhile. ;)
Thanks for this!
Not quite a *myth*, since as you see, there are things that require bit-widening from 1 to 8bit. Which, for better or worse, people, including some who certainly are savvy, consider 'PCM narrow'. AFAICT you still can't do *all* common production moves in a 100% purely DSD environment.
And really, if even fairly simple 'editing' requires resort to such expensive Rube Goldbergian technology workarounds....... :rolleyes:
Again, where is the sonic payoff?
Not quite a *myth*, since as you see, there are things that require bit-widening from 1 to 8bit. Which, for better or worse, people, including some who certainly are savvy, consider 'PCM narrow'. AFAICT you still can't do *all* common production moves in a purely DSD environment.
Understood,but it's one thing to say "it's not editable,period" and another to state as such considering the hustle,price,etc
And even the "wide" format,is not PCM,so no such conversion needed as we often read.
So it's money,training (=time),etc.
But technically they did make it.
Well, that last exchange illustrates perfectly what I mean when I wrote about the sex of angels. :)
The whole point of going digital is that doing things by crunching numbers allows better accuracy and better consistency across a batch of products than is possible by manipulating physical quantities (voltage, current, phase, etc...) moreover while being cheaper and easier.
By crunching numbers, it often if not always happened that the output results of the calculation must be expressed with numbers requiring more digits (ie more bits) than the input number. If one is not prepared to face this mundane reality, the only choice he had is most probably to stay in the analogue domain.
Why there are people who adamantly oppose to expand the bit-width of sigma-delta signals and insist to keep them 1 bit when there are 1 bit at the start (DSD) is beyond me. Is enlarging bit-width contrary to good moral? Forbidden by the Vatican? Satanic? Infringement of a state law? I don't no. But for me, it is certain that the reason is outside the realm of engineering and is rather a moral or dogmatic posture whose foundation I struggle to understand.
Speaking of noise, you may want to add some tones with heavily shaped dither to the arsenal, for CD-only players. This would give you a better estimate of true analog performance.
Just for the record, I think the following graph illustrates the kind of result one would expect by the use of such a test signal. It is an FFT obtained with an Audio Precision of the output of a player when reproducing a very low 16 bits/44.1 ksps PCM signal with noise-shaped dither engraved on a test CD:
This graph was published in the Italian magazine AudioReview, where it happened that such measurements are publised from time to time: https://www.audioreview.it/prove/storiche/mcintosh-mcd301.html
It reminds me of tests I performed couple of years ago with files published by Focal (in fact a studio made them, on their behalf). Maybe I still have them somewhere.
At the time, I could see heavy noise shaping. Here below an FFT I kept, retrieved from my archive. The orange trace is TPFD dither (16bits) vs Noise Shaping from that studio (1kHz sine @-14dBFS, frequency linear scale):
Above all, we see that the argument of piracy of recordings does not hold up. Because Philips and Sony were not able to force their musical branches to publish their new releases and their reissues in the form of SACD-CDs in Europe, the largest record market, and in the United States, and only the Japanese subsidiaries of these major publishers have done so. To my knowledge in classical music, only Mercury, which belonged to Philips-PoluGram, will publish it to reissue its archive from the 50s and 60s... And Decca who published a few that I own and quickly stopped...
However, Sony and Philips-PoluGram were the two majors that dominated the world record market. Reason why the CD was imposed: these two giants imposed the CD on all the publishers belonging to them. EMI, which did not want to be burned by the failure of the SQ matrix Quadriphony ten years earlier, came to it reluctantly...
DVD-A failed: it must be said that it was incompatible with listening to music without a screen to adjust the OSD, that audiophiles rejected players mixing audio and video, that BD Audio was only released later in a market for physical products so in crisis that all media are good for making a little money: CD, SACD-CD, BD and LP...
Piracy is forgotten: streaming, in other words listening for a small fee, has made it out of fashion, whereas today it is disconcertingly easy to copy the stream of a platform.
The paradox of all this being that Philips Classic and DGG have recorded a large number of their records in quadraphony since the 1970s... which they never released in this way... even though SACD allowed it... But we can find them in the form of files at Pentatone which uses them under license with full knowledge of the facts, since this publisher-producer was founded by the technical team of... Philips Record...
And DSD was also not used by Sony and Philips-Polygram at the time to copy their analog archives stored on magnetic tape media which were already aging terribly... they did it in 24/96...
So what was DSD really for?
Was it a stillborn technique... born in the minds of technicians who thought "analog" because they felt that PCM was less "musical", less "natural" than analog sound and therefore than DSD? It's not impossible... I've worked with technicians professionally who still think so...
This summer I heard on France Musique, an old radio archive: an interview with the founder of Harmonia Mundi who makes this anti-digital and therefore anti-CD speech... and who was one of the first to publish. ..SACD...
This story of DSD and SACD is strange.
Funny thing: the first publisher to have published a purely DSD SACD was Lyrinx, a small publisher from Marseille: with the help and support of Sony Electronics who lent it a Sonoma station and promoted this disc in these terms... But curiously not Sony Records... whose director of the French branch told me that "New York doesn't want to let us publish any here."
@Scytales Everything you said is extremely interesting and obviously from years of research and gathering of data. Thanks again for sharing all of that.
It took me time to digest, and I’m not done yet anyways.
One question about editing in DSD, and especially in the context of mixing multiple tracks with some heavy processing like equalization: what about noise? How is it managed? Would you know?
Thanks
Flo
@Haskil Thanks for the complementary information, very interesting too. It's not always easy, even for a huge group, to "force" all its worldwide subsidiaries to follow the same route, especially if they are asked to participate financially. This is where one might encounter resistance, like from the local CFO who does not agree with the business case, to the Market head who's set other objectives for the local brands and which potentially conflicts with the latest idea from the Head Quarters :)
Flo
Just for the record, I think the following graph illustrates the kind of result one would expect by the use of such a test signal. It is an FFT obtained with an Audio Precision of the output of a player when reproducing a very low 16 bits/44.1 ksps PCM signal with noise-shaped dither engraved on a test CD:View attachment 392291
Thanks for the reference and link.
There's another measurement published, this one (39kHz & 42kHz) with a view in linear frequency scale, up to 50kHz:
I don't have that double test-tone on the Denon SACD, but there are single 15kHz & 30kHz test tones overlayed (so it's not intermodulation distorsion test here), with the same representation, it shows:
But I think it's not representative, because if I extend the view to 96kHz:
There we see the (shaped) noise but also distortion as high as -60dB.
Would you know what test SACD disc they use?
Cheers
Flo
