Hi Scytales,
Couple of updates. First of, the AL24 is deactivated on the DCD-SA1, when playing SACD disc (DSD) which means it's only active with PCM input.
Here below, find an overlay of Pink Noise (Test track 8) and 1kHz @-16dBFS (test track 12):
I kept the view in dBFS on purpose so that the two traces overlay. You can see noise shaping starting just after 20kHz. Even with the single sine 1kHz, there is a massive amount of noise generated here. Is it part of the SACD recording, part of the DCD-SA1 conversion, or both, I can't know.
Pink Noise (orange trace) on top shows that the noise generated by the noise shaping technique takes over the pink noise itself at roughly 55kHz.
Note that the tracks are only 20sec long. The Pink Noise is random, no periodic as a I use, but it does not change anything.
And as I've put a lot of the same view in linear scale before, and for the sake of comparison, I'll add exactly the same view as above, only change is linear frequency scale:
It gives a different perspective, especially as to the noise of concern generated by the
Denon DCD-900NE and especially the
Marantz CD6007.
I will now test the various music tracks and report later.
EDIT: This is below an analysis of musical content (1700+ FFT averages over more than 5min). I overlaid SACD layer (green), CD Layer (red) and a last option of the DCD-SA1 which allows conversion of DSD to PCM (blue) before going to the DAC (Linear Frequency Scale for a better view):
The track (#27) in the Denon audio check SACD is
Mahler: Symphony No. 2 in C minor "Resurrection" - 5th movement closing part (F.!) (Conducted by Wenceslav Neumann, Czech Philharmonic Orchestra, the choir, Gabriela Benachikova-Chapova (soprano), Eva Landova (alto))
Note that the view is in dBFS to let the measurements overlap. This is important because the pick of noise shown by green trace here, out of band, reaches -48dbr at 73kHz. Converted to % this is 0.4%...
This view shows that it is the player which is adding this shaped noise (green trace increasing starting from 25kHz). So when processing DSD data, there is a huge amount of noise added. This is not a surprise and I'd encourage you to read the
Bartok review from Goldensound who showed massive amount of similar noise added when using DSD filters.
Back to our view above, the CD layer shows exactly the same overlay in audio-band. We see the low pass filter starting at 20kHz, which is the effect of ADC when creating/recording the CD at 44.1kHz.
Last and not least, the blue trace is an optional conversion from DSD to PCM before analog conversion (that the Denon DCD-SA1 offers). This view shows that there is probably noise created by the noise shaping technique on the DSD recording itself, but it is attenuated by the subsequent oversampling filtering of the PCM data stream.
And side note when it comes to the advantages of SACD over CD: at 22kHz we can still see "music", compared to CDA. That said, relative to the max signal, the difference is -80dBr vs -100dBr. In other words, even if the SACD can record and reproduce music beyond 20kHz, its energy is null, at least in this instance.
As per the above view, I'll continue sticking to CDA
And so the Denon DCD-900NE is a killer.
Flo
