Denon X3800H Apple TV CEC issue – solved
coolstuff
CEC not working when Apple TV connected to Denon X3800H.
I really appreciate to know if other users can report CEC working (power switching AVR+TV on/off and volume control up/down via HDMI) when Apple TV 4K 3rd Gen with TVOS 17.5.1 is directly connected to Denon X3800H AVR with latest firmware version 6300-7153-9042-4730 DTS Version 4.30.10.15. This is to gain evidence about a software or hardware issue.
My use case scenario:
TV Sony 4K (Android) <--> AVR Denon X3800H with directly connected to AVR:
  • STB VuPlus DUO 4K SE
  • Apple TV 4K 3rd Gen
  • Sony BlueRay Player
TV is a Sony with ARC (no eARC), so I try to avoid using ARC in this scenario.
Power switching on/off devices using respective remotes as well as volume control via HDMI. This has been working well before.
Two weeks ago we had a light stroke nearby, which trashed my Denon X3800H and the SAT receiver (SetTopBox STB). The Smart TV as well as the Apple TV seemed not being affected – but this might be wrong assumption.
The new equipment recently has arrived (same AVR) and a very similar new SAT receiver, but the Apple TV is not accepting to work with CEC esp. when directly connected to the AVR even as the only device being connected.
Since my Sony 4K TV only supports ARC the use case is that all HDMI source devices are directly connected to the AVR – as it was working before the light stroke event.
I could restore AVR settings from a previously saved configuration so I am quite confident that all AVR settings are the same.
  • HDMI-Audio output: AVR
  • HDMI PassThrough: On
  • Pass Through-Source: last
  • Remote control Source: On + Source
  • HDMI Control: On
  • ARC: ON
  • TV Audio-Switching: On
  • Powerswitching: All
  • Energy saving: On
I am curious to better understand if this is a hardware or software issue. There are many reports about Apple TV (ATV) issues concerning CEC esp. starting with introduction of TVOS 17.4. Some report that things have been solved with firmware updates. But some still report CEC being broken until 17.5.1.
This post is not about discussion if CEC shall be used or not.
Now since I am affected with this very basic issue that whenever I connect the Apple TV to my Denon X3800H AVR the ATV CEC function to control TV or receiver is turned off and cannot be turned on. The ATV message says that I shall turn on CEC at the TV and Receiver respectively. If the STB was connected then CEC is not working any more.
It is obvious that I shall review if I can borrow an ATV for testing. But I think asking the wider community has much more potential of gathering the desired information at lowest effort.
What else has been tested:
  • ATV connected to various HDMI ports as single HDMI input (no impact)
  • with CEC enabled (TV+AVR) variation of ARC enabled / disabled (no impact)
  • settings of TV switching (AVR) does not have any impact
  • different cables did not have any impact
  • A test using the ATV connected directly to my Sony TV (Android): CEC could be enabled and ATV turned off the TV during power down. Volume control was not possible using the Apple TV remote.
  • A test using the ATV connected to an LG Smart TV (WebOS): CEC could be enabled and ATV turned off the TV during power down. Volume control was not possible using the Apple TV remote.
Firmware: Apple TV recently being updated to TVOS 17.5.1 as well as DENON firmware was recently being updated. X3800H Firmware is being reported as Version 6300-7153-9042-4730 DTS Version 4.30.10.15.
So I cannot comment about possible impact of those recent software changes. But the desired scenario where 3 devices (cf. use case) were connected to X3800H with CEC and without using ARC control enabled was fully functional before. And the test with the LG TV has same behavior without volume control being functional.
If Apple TV is connected to AVR then CEC functions do not work anymore. Disconnecting ATV requires a power cycle to get CEC working again.
Tests have been carried out as careful as possible using following this sequence:
  • Make sure HDMI settings are correct (STB features input settings for TV as well as AVR HDMI ports)
  • Power off all devices from mains
  • Disconnect all cables
  • Power on all devices then power off again to reset CEC
  • Connect HDMI cable for 1st device connected to AVR to test
  • Power on AVR and then power on the 1st device respectively.
  • Then power off both and try to power on using device remote control
  • Then add cables for next device before power on next device connected
Thanx in advance.
Tom
I’ve had both newest version of the Apple TV 4K and cec works perfectly. It’s like I won the cec lottery. The Apple TV is hooked through a x3800h to an lg c1. All three remotes work and have never failed for synchronized power on or off.
I’ve had both newest version of the Apple TV 4K and cec works perfectly. It’s like I won the cec lottery. The Apple TV is hooked to a x3800h to an lg c1. Both remotes work and have never failed for synchronized power on or off. The lg remote even can control the Apple TV. It’s literally perfect.
Thank you @dfiler. This was my experience before the light stroke. Good to know but now I have to realize a broken ATV.
I should also say though that the Nvidia shield pro is not cec nirvana. It is consistently flakey with the same setup.
further investigation scanning CEC bus confirmed that if ATV is on the bus there is failure ...
using Raspberry Pi plus cec-utils this is quickly performed.
Good info.
I have both latest shield and apple tv 4k plugged in through my 3800 and use CEC from my Sony a95l with no issues.
So are you going to order another apple tv?
