x4800h eARC volume low compared to 2ch music
Mort
My eARC from a Sony Bravia to a Denon x4800h is about 40 (0-100) compared to HEOS, Wiim or Sonos digital streamers. It also will not play above 92, it's just stuck there (no clipping). I can't get movies loud enough, although they can be loud, it's nothing like the ear piercing loudness of the 2ch music.
We switch those inputs and the TV on and off a lot and often the AVR is on all day.
It's really become an annoyance to be blasted by music. It would be slightly better if the damn x4800h eARC volume control wasn't so painfully slow (via TV remote).
The x4800h has the ability to reduce an input by up to 12db, which I did (-12db on
the streamers) and that reduced the issue to about 15, still too much. I would be close if I could adjust eARC +12db but eARC input isn't adjustable in the x4800h even though others are.
Wiim and Sonos allow a preout adjustment out which works to compensate but there is still the fundamental issue that eARC is very quiet.
eARC volume is adjustable from the source menu but it's kinda tricky to do. Play eARC audio and then press setup and follow the front display menu to look for source settings and increase the digital input level using the remote. It's doable but you may have to try many times because it may get you to lose the eARC audio making the source setting unavailable. Just try again and again until you get it right... It took me a while with both my old X4400H and new X4800H.
I bought the x4800H and are happy with it so far I have front left and right Paradigm studio 100v4 and c690 centre adp590 surrounds two B&O 610 subs and two earthquake 8inch ceiling height speakers blueray BDP105D I listen to 80%streaming tidal music and and tossing up buying a intergrated amp to power front speakers what would be a ideal product
