Of course!
but i cant read anything about pre/pro mode that the Denon has.
I hear you, but why can't you read anything about Denon's?? For example: Marantz SR7013 - HDAM = Denon AVR-X4500H for analog input, and for digital, Marantz AVRs likely also use the slow roll off DAC filter so for those with good hearing up to 20 kHz may hear a difference, but that does not affect SINAD in the audio band. It is a sure bet that the SR6014 is like a AVR-X3600H, but has a slightly stronger power supply and has HDAM.
We don't know the effect of HDAM on SINAD, and I can't wait to see it either, but I though the Denon's measurements should give you an idea,like getting you in the ball park.
You can also reference to the measurements of the AV7705. The SR6014 may measure better, but again, should be in the same ball park though.
Anyway, I bet Amir will be ready this week to measure the SR6014 because iirc, he did say he would do it before the Denon X3700H.
