I've been reading Amir's work and subsequent forum commentary over the last 6 months. I greatly appreciate his effort to shed light on how well things work "under the hood", and the usually constructive dialog that results.
I’ve read this entire review/thread and am having a hard time wrapping my head around some of the issues. Here’s what (I think) concerns me and my understanding of the issues:
1. Downmix/HDMI issue- It’s hard to figure out the applicable circumstances. I run a 7.2.2 ch. Yamaha system (looking at Denon for 7.4.2 at some point). Source components are all HDMI; outputting multichannel movies/TV/SACD (BD/Dish/Roku) and stereo (BD-CD and Rasp Pi). I listen to stereo as stereo, and may use zone 2 for stereo in the future. Does it sound like the issue is applicable with my usage?
2. Pre-out “off-load”- Per Amir in the review: “We see the typical high harmonic distortion due to internal amplifier stressing the power supply causing the DAC to underperform. Fortunately in this amplifier we can turn them off for the fronts…” (1)
Just to clarify. Is this an input signal routing or an amplifier power configuration option (or both)? Are the pre-outs always “hot” or does disabling the amps then route the signal to them? If they are always “hot”, the performance advantage is achieved, not just by “jacking in” to the pre-out, but also requires disabling the amplifier(s). The 2 “routing/disabling” options are “L/R” and “all”.
- What is happening to the “off-loaded” and improved L/R DAC performance when the 7 other amplifier channels are in use? (It’s not clear to me if they were driven during the review).
- What do the 9 other DAC and 7 amp channels look like when L/R has been “off-loaded” (reduced power supply load)? Are they also improved (distortion/headroom…)? Is it possible to sample check DAC/amp channels- C, L sur, R height? Probably too late…
- Related but not exclusive to the discussion above. Could anyone comment on the relative power requirements and utilization of L/R vs. C vs. surround (yes I realize this is source/mastering dependent). Any sense of the generalized value of offloading L/R or L/C/R from a receiver and the subsequent reduction of power supply load. I would think there would potentially be large advantages in the remaining channels amplifier headroom, power supply loading (system), heat, and potential crosstalk (EMI). Off-loading all amplification would of course maximize all of the above.
3. 1.1/1.4V preout (best/max)- Seems on the thin side, but workable with most of the amps I’m looking at. Is the blue trace in the attached “Pre-out w/ amps on/off” graph (near the end of the new part of the review) reflective of “L/R” or “all” amps off. If “all”, what would it look like with only L/R off? A realistic usage scenario.
