Denafrips ARES II USB R2R DAC Review
Killingbeans
Bjerringbro, Denmark.
Thanks for sharing, I didn't know about the brain plasticity.
It's a mechanism of biology that's really great for survival and energy conservation, but absolutely catastrophic for judgement of long term changes in audio.
It's a godsent for the high-end industry and snake-oil vendors though. The myth of burn-in as a physical phenomena makes customer satisfaction much, much more manageable.
Echoic memory makes a mess of the short term stuff. If you want any sort of reliable judgement in A/B comparisons, there's no way around instantaneous switching.
By the way, this could be a very interesting test to be made by @amirm using a Denafrips DAC if there is any available.
Before burn-in and after let's say 100-200 hours with a new firmware update.
It would be beating a poor horse that's already been dead for a long, long time.
As far as I remember, @amirm has already done a few investigations of before and after burn-in/break-in as part of some reviews, just for fun. They all showed what could/should be expected: zero difference.
Klipscher
Biggest upgrade with the new firmware is it fixes the issue with micro skips at start of track I was experiencing with the wiim pro. Used to happen when there was a resolution change in a playlist on tidal.
For me it completely fixed the issue. Only other differences was in the bass but without the equipment to test this just going by audio memory so I leave it at that.
Killingbeans
Probably not joking. There's no limit to the batshit crazy stuff people are being fooled into believing in this hobby.
Critical thinking isn't exactly encouraged by the "authority".
Best case, it's the last death cramps of the audiophile industry as it has become. Worst case, it's just biology doing its thing.
nawfal07
Firmware burn-in, first time I heard this, on ASR to boot, ironic bordering to moronic. I guess I have to burn-in my countless Windows 11 updates before using my laptop.
Killingbeans
I'd imagine it's common lore in places like Audiophile Style, and then it oozes out and contaminates everything, unless people are quick with a mop.
Veri
What can I say those bits and bytes aren't gonna burn in themselves....
:p
Jimbob54
No no no, you can of course use the laptop straight after an update but it will only perform optimally after a few days of constant use.
Killingbeans
It's a really fascinating thing about the hobby. How it sort of creates a bubble around itself with an alternative logic inside.
There are so many hard held beliefs in high-end audio, that deflates themselves instantly as soon as you try to apply them to any other comparative non-audio use case.
It's like Hi-Fi is used a little safe zone, where people can freely exercise their primeval lust for mysticism and the supernatural, under the presumption that it doesn't do any real damage.
Jimbob54
I suspect a lot of it results from the ears being the ultimate judge of a system in audiophileland. To admit any perceived differences/ benefits might be on the human end of the chain would be to admit the ears / brain of the listener are imperfect. Hence, everything has to be explained away by some change in the system. Burn in being a convenient fall back.
CleanSound
That's O type transformer which is different from commonly called Toroidal transformer. (the cross section is also toroidal) These have even less magnetic leakage which is ideal for audio.(and relatively small chassis) They are expensive and perhaps to you an overkill but good.
Hi John,
Can you explain the engineering reason why Topping moved away from linear power supply to switch mode power supply? I know that with SMSP, you can much much less magnetic leakage, but it also has high frequency noise caused by the switching/pwm.
Does the high frequency noise caused by SMPS affect audible performance and if so, how does Topping remediate this engineering challenge.
Also, what is Topping's view on R2R vs D/S DAC? Will Topping consider a R2R DAC?
Jimster480
Tampa Bay
I thought about that thread. But I think that thread is done. His last reply was back in July.
The post you replied to is from January 2020 though.
I don't really think that Topping will do an R2R DAC because there is no reason for this...
funnychap
Here's my Youtube video of my new Denafrips Pontus II 12th-1 dac versus Denafrips Ares II 12th, used with the Denafrips Iris 12th (a DDC) via I2S.
Love it, sounds even better (better vocalist, bigger soundstage, more 3D depth, clarity, I can hear new instruments).
streaming source=Apple Music lossless, hi-res lossless, spatial audio surround sound
Jimster480
Tampa Bay
Makes no sense... $2500... I would bet it doesn't out perform the $200 DAC's on this site...
There is no "magic" in R2R; DS does the same thing but using modern technology. The Waveforms on DS DAC's of today are better than the best R2R of the yesteryear.
voodooless
Netherlands
And obviously, you're using the thing in NOS mode :facepalm:
And it seems like the Pontus II does more than 10dB worse than the product reviewed here:
See:
Killingbeans
I agree with @tw99 The old DAC must be absolute garbage if it manages to mask entire musical instruments :D
Don't take this the wrong way, but it's far, far more likely that you were simply paying more attention when listening to the new one:
D
Deleted member 5641
Guest
Haha that was one of my wake up calls when coming to Audiophilia. I’d hear some never before heard detail on the new gear… until switching back to the old, and yup, there it was.
While proper level matched DBX is hard to pull off for a lot of people, a simple rotation *back* to prior gear often reveals wonders.
PS - Steve Hoffman shared some crackpot theory on this on shtv.
