- Joined
- Feb 23, 2016
- Messages
- 20,869
- Likes
- 37,890
For an RME Babyface Pro FS in loopback. It is fully flat to 20 hz. Is about .05 db down at 10 hz. Only about .1 db down at 8 hz though the level is slowly fluctuating. I don't know if it is some sort of DC offset or what is causing it. By 5 hz more fluctuating which averages out to about .35 to .4 db down. At 1 hz there is lots of fluctuation with an 4 sweep average over 128k fft of a bit over - 7db. I of course don't know how much is the ADC or the DAC.Happy to be corrected. So what you are saying is the current crop of cheap Topping/RME/SMSL DACs will output a 1Hz sine at 0dBFS at full rated output voltage (same as 1kHz)?
At what point do these supposedly properly designed source products pull the pin? (0.5Hz?) You cannot be inputting DC out of a DAC.
Using the Topping D10 Balanced for the DAC portion the results are the same almost exactly. So maybe the ADC is what is limiting below 20 hz. So both DACs must be pretty close to flat to at least 10 hz. Maybe lower if the ADC is the bottleneck below 10 hz.
