Both. Do you have that?What is it I need data to verify, Amir:
- That sporadic high current draws cause noise injection on the ground plane of the motherboard?
- That MicroRendu SEEM to be addressing this?
Have Frank listen to it via Youtube so we can tell how it sounds and whether it has those dreaded artifactsI'm willing to send one in to Amir to measure against the Microrendu.
What do you think is the logic behind Keith Johnson's suggestion that you so assiduously cling to?Both. Do you have that?
This has nothing to do with the question you asked me. So I repeat: when you have a theory that this and that electronic tweak (as separate from architecture) needs to be accompanied with data.What do you think is the logic behind Keith Johnson's suggestion that you so assiduously cling to?
What might be the underlying reason why sporadic activity on a computer may be detrimental to the sound?
Any suggestions?
My apology for being so far behind Mike. My son is getting married this week and I had to get the Entreq tested as that is on a short term fuse. Your setup requires a lot more set up and I just have not had time to do it.Best to have Amir measure it. The best way would be using the USB to SPDIF/AES/EBU bridge I sent in. He can measure 3 setups
1: His server build connected to my bridge
2: His server combined with the Microrendu in roonbridge mode connected to my bridge
2: My server connected to my bridge.
Science doesn't know everything, not everything can be measured, blah, blah.Best to have Amir measure it.
Science doesn't know everything blah, blah.
OTOH, audiophiles can hear everything, especially the stuff science doesn't know about yet.
So record the "sound" of your widget via your cel phone, post to Youtube, have Frank clear it for artifacts.
Then, the final step to confirming audio greatness, is not controlled blind tests, but rather, sending it to Bruce Browne of Puget Sound. JKeny let me in on this little secret, so it's really no secret any more.
Better than a $350 laptop? Pray tell how..It's also going to be only $350 so it's a great alternative to a full sized computer for those on a budget.
Oh you've turned into one of those deaf lab coat people. Ok.I would rather have the measured results do the talking.
The AP agreement states you must don a lab coat and stuff putty in ears when measuring, not that Amir wasn't stone deaf alreadyyour AP buyer agreement mandates that you dispel any internet audiophile rumor or supposition for free.
