I get the impression you are not keen on the DIN connector.Ugh. Flimsy and with unreliable physical coupling.
Edit
The 6.35 mm TRS was used (still used?) in broadcasting for years. It's pretty reliable.Since the definitive connector for multichannel balanced connections has yet to establish itself (even DisplayPort has been used before), you pretty much have to go with what makes most sense to you. Even 12x 1/4" TRS would be a fair bit more compact. If it's not too fiddly and you can get ready-made audio cables (studio retailers seem to be stocking several options, e.g. prices at Thomann ranging from about 25@ to 120€ a pop), DB-25 wouldn't be such a bad bet.
Not designed for audio, but industrial 8mm (3 & 4 pin) and 12mm (4, 5, & 8 pin) screw connect are very available. I use them with transducers. In the USA, try AutomationDirect.com for their reasonably priced range. This picture is the 8mm 3 pin.That being said, as far as I understand, my options are
4) ...
110Ohm DMX cables with 5pin XLRS seem to be readily available, and I was wondering if these can be used for audio.
I have horrid memories of russian-built (soviet era) din plugs. It sounds, they were not much better on the other side of the wall;-)Ugh. Flimsy and with unreliable physical coupling.
Two years ago I have built a 12ch amplifier using 3e audio modules. It is working flowlessly ever since.
However, 12 xlr connectors produced quite a bit of clutter and ate significant space of backplate (I use the HIFI2000 2U enclosure from audiophonics.fr).
I am looking for alternatives to save some space to eventually add a fan, but I would like to keep balanced connection between MiniDSP 4x10 and the amplifier (I have not tried unbalanced yet, and because balanced is here, utilizing it seems reasonable). That being said, as far as I understand, my options are
1) 5 pin stereo XLR connectors
2) 3 or 5 pin miniXLRs connectors
3) 3 pin TRS
4) ...
5pin XLR looks as an interesting option: not only using it would allow to divide by 2 the surface used by connectors, but the wiring will also become simpler in this case.
However, it looks like they are not really commonplace in audio, and I am wondering how "standard" 5pin balanced (stereo) connectors are.
I have found 2 schemas of the wiring of this connector
View attachment 150713View attachment 150714
which seem contradictory (unless I do not understand what is "hot" and what is "cold").
That being said, 110Ohm DMX cables with 5pin XLRS seem to be readily available, and I was wondering if these can be used for audio. I am thinking to give it a try--my cables are only 30-50cm long, but I would be surely happy to get an educated opinion.
My favourite solutions for these situations are those very cute and reliable Mini XLR connectors
https://www.amphenol.com/node/4901
yeah I was going to suggest lemo, or amphenol, great stuff, but pricey. love them, but for 12 balanced channels youd end up spending over $500.
i'd vote for DB25. actually not that difficult to solder. since its balanced audio, is there any reason you actually need a ground wire for each channel? I would expect that would not even be desirable. 25 pins is 12 x 2, plus 1 shield/gnd. or do you need to have it XLR at the other end like a breakout cable? if its DB25 -> db25, I dont see why 25 pins wont work. ground doesnt carry any return signal in balanced audio
Have a search for audio snake ethernet. Each cable can carry 4 pairs of balanced signals. If you are building everything on your own it makes most sense.
Someone used them in their audio electronics a ways back but I cannot recall who.
Cute, yes, but I have not found them to be particularly reliable.My favourite solutions for these situations are those very cute and reliable Mini XLR connectors
Me, too.i'd vote for DB25.
Well.. they actually have everything on their page, just choose product and click "download" to get technical drawing in PDF
You are probably thinking of Mark Levinson. the switchcraft mini XLR are a better class of mini xlr, if one must be used, but they arent a Lemo. The swiss watch of hi end scientific/industrial connectors. Again, not recommending it here. While they do have stuff in their catalogue that would take care of you nicely. they would cost you an arm and a leg. The N series, for nuclear applications ... so sexy ... I shudder to think of the cost.Someone used them in their audio electronics a ways back but I cannot recall who.
Me, too.
Probably.You are probably thinking of Mark Levinson.
Amen.the switchcraft mini XLR are a better class of mini xlr, if one must be used, but they arent a Lemo.
I would think it would be fine. have you got a means of testing it with one channel? if there is a shield in your cable, tie that to the chassis—and chassis only—at BOTH ends (and the db25 shell casings if they are metal) not just one end, both. that isn't signal ground and you shouldnt tie signal ground and chassis ground together at this point (if at all). its not possible to give a clear cut answer, but if you are able to control the way this goes, because you are DIYing: I would expect its possible to connect just one GND pin at minidsp end (all channel grounds will be connected I expect) to signal GND at the other end, or Chassis GND at the amp end only would work too.Thanks. Indeed, I am wondering if I need multiple ground wires on the MiniDSP side. Would it be OK if I just connect the (25-th) ground wire with the amplifier box?
