Two years ago I have built a 12ch amplifier using 3e audio modules. It is working flowlessly ever since.
However, 12 xlr connectors produced quite a bit of clutter and ate significant space of backplate (I use the HIFI2000 2U enclosure from audiophonics.fr).
I am looking for alternatives to save some space to eventually add a fan, but I would like to keep balanced connection between MiniDSP 4x10 and the amplifier (I have not tried unbalanced yet, and because balanced is here, utilizing it seems reasonable). That being said, as far as I understand, my options are
1) 5 pin stereo XLR connectors
2) 3 or 5 pin miniXLRs connectors
3) 3 pin TRS
4) ...
5pin XLR looks as an interesting option: not only using it would allow to divide by 2 the surface used by connectors, but the wiring will also become simpler in this case.
However, it looks like they are not really commonplace in audio, and I am wondering how "standard" 5pin balanced (stereo) connectors are.
I have found 2 schemas of the wiring of this connector
which seem contradictory (unless I do not understand what is "hot" and what is "cold").
That being said, 110Ohm DMX cables with 5pin XLRS seem to be readily available, and I was wondering if these can be used for audio. I am thinking to give it a try--my cables are only 30-50cm long, but I would be surely happy to get an educated opinion.
3) 3 pin TRS
4) ...
